- Thank you received: 33
Please try the latest firmware with the bug fix for this.Hi, changing the direction of the DMA axes shift is frequent, it happens without turning LinuxCNC off and on. I have an XYYZ configuration, when homing it happens that the HOME switch Y1 is turned on (physically it is not), I have to turn linuxcnc on and off several times for it to start working. sensor, cable and input changed. It behaves the same way in fw. remora-rt1052-3.0.0.bin and fw.remora-rt1052-2.1.0.bin. Couldn't it be related to the change in dma direction?
This is the error I get when trying to start linuxcnc.
Debug file information:
iopl() failed: Operation not permitted
cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allowed
Note: Using POSIX realtime
remora-eth: dlopen: /usr/lib/linuxcnc/modules/remora-eth.so: cannot open shared object file: No such file or directory
./remora-eth.hal:7: waitpid failed /usr/bin/rtapi_app remora-eth
./remora-eth.hal:7: /usr/bin/rtapi_app exited without becoming ready
./remora-eth.hal:7: insmod for remora-eth failed, returned -1
74582
Stopping realtime threads
Unloading hal components
