2 years 11 months ago #286895 by cakeslob
0jw post your hal/ini file
2 years 11 months ago #286909 by hanskuster
I was able to confirm the direction output issues. My approach to getting the step and direction outputs into a "known" state during restarts was not consistent. So, with this bugfix I'm reading the actual output port DR register and then performing a direction change if needed. Happy testing and thanks again for the feedback. We'll get this stable.
I'll merge the bugfix branch once we have some feedback.
github.com/scottalford75/Remora-RT1052-c...t1052-3.1.1-beta.bin
Hi scotta,
I'm sorry for not seeing Your bugfix immediately! I was away for a short vacation.
I tried the version 3.1.1-beta. After every start the direction was always correct. I did about 15 starts.
The only problem I found instead is, I'm not able to upload a configuration. The remora stops its timers and that's it. The config upload repeats its requests, but doesn't get a response from the remora.
As a test I retried to upload the configuration again with version 3.1 and there it did work.
Regards, Hans
2 years 11 months ago #286915 by scotta
Hi scotta,
Regards, Hans
Thanks for testing! And discovering another problem. I'll check it out.
2 years 11 months ago #286924 by 0jw
the latency actually looks pretty bad on this desktop. I have youtube running in the background and some files open.
2 years 11 months ago #286926 by 0jw
This is in /home/cnc1212/linuxcnc/configs/remora-rt1052-basic/
But I have another folder not in configs named Remora-RT1052-cpp.
2 years 11 months ago #286931 by zmrdko
Try isolcpus=2,3 first
Time to create page: 0.744 seconds
