Hi scotta,Hmm. I'm guessing this is with the DMA stepgen. I thought my last changes had solved that issue. It's not a LinuxCNC config issue.
If you could monitor the situations which lead up to this bug that would be appreciated so I can try to narrow down the underlying cause.
After a bit of fidling I completely given up on the pico route and just ordered 2 cheap ST-LINK's . With the particular ones that I got , it turns out they work out of the box for flashing the EC500. I didn't even needed to flash the custom firmware on the stlink. If you get the ST-LINK try first a flash just the way they are before flashing one of them as per scotta instructions. Unfortunatly I don't have the time and knowledge to dig deeper and make the pico workI'm having a similar problem to user oficinerobotica when trying to flash a ec500 with a pi pico using a windows machine. The board date is 2022-09-07.
When I try to use
pyocd flash remora-rt1052-EC500-beta.bin --target mimxrt1050_quadspi -v
I get the error
0001433 I Target type is mimxrt1050_quadspi [board]
0001534 C No ACK received [__main__]
I'm not using resistors and don't have 3.3v connected to boot.
I have gnd, 24v, com- and com+ connected to power.
Anyone have any ideas as to what might be the problem?
