Hi cakeslob,Hey Hans,
Since we are using external hardware, I dont think that we use a basethread. That is mostly for parallel port setups.
Its good that it shows up in the preview
Yes, you will get the higher stepgen frequency with the RT1052 NVEM board as well. Firmware is the same, just a different configuration file. For the NVEM I think you will only get up to 3 hardware encoders.Is the firmware 3.0.0 can also for nvem(v2 300khz) with rt1052
