- Thank you received: 13
As per Cakeslobs comment. Leave the basethread as 0 and ignore the error message.Hi cakeslob,
thanks for having a look into my problem!
The axis move in the preview screen, but the motor doesn't get any signals.
I had an error message for BASE_PERIOD, I don't remember which one, but setting it to the same value like SERVO_PERIOD fixed this for me.
When I had both values to 1'000'000 I constantly got an error message about latency, I should run the latency test, although I switched off all power saving options in the bios.
The latency test gave me results of around 30'000 which should be good.
My goal for now is to make the system moving and then I can check/fix the latency, if that will be an issue.
Regards, Hans
