I made some modifications to see if I can modify the graphical interface from axis to qtplasmac, I get an error message I have to modify other parameters?
Traceback (most recent call last):File "/usr/bin/qtvcp", line 545, in <module>_qtvcp = QTVCP()^^^^^^^File "/usr/bin/qtvcp", line 261, in __init__window.load_extension(opts.usermod)File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 269, in load_extensionmethods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 312, in _load_handlersobjlist = h(halcomp, widgets, self.PATHS) # this sets the handler class signature^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 6099, in get_handlersreturn [HandlerClass(halcomp, widgets, paths)]^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 229, in __init__float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^TypeError: float() argument must be a string or a real number, not 'NoneType'
p, li { white-space: pre-wrap; }
