2 years 7 months ago #295177 by vpomerleau
For pin 1 and 9 you need the swich on the controller set to standard mpg to test them
2 years 7 months ago #295178 by Cold Turkey
Yeah mate, I did that.
2 years 7 months ago #295181 by vpomerleau
Maybe controller version is different, I got May 2023... how do you make your tests? Are you louking at remora input or nvmpg inputs in halshow? I use the connector that came with the controller and screw a wire in pin 10 (com ground) and touch the other pins with the other end of the wire, the checked the remora.input.xx
2 years 7 months ago #295183 by Cold Turkey
My controllers are from multiple batches. Watching remora.input in Halshow. I have the other pins working and yes I'm using the same testing methodology as you. I will try another controller when I get the opportunity.
Thanks for the replies.
2 years 7 months ago #295213 by vpomerleau
@ Cold Turkey
I found an extra blank line in the config file I uploaded, not sure if it's what's causing your problem, I replaced it in my original post.
If you want to make more tests, here's the pins that are used in the github config file. Every other pins can be tested.
P3_12
P3_14 @ P3_20
P3_22 @ P3_26
P4_00 @ P4_15
P4_24 @ P4_25
P4_27 @ P4_31
2 years 7 months ago #295259 by Cold Turkey
Yeah thanks for that, I had already tested the range that had not yet been assigned but got no results. I may have bad hardware.
Time to create page: 0.168 seconds
