- beauxnez
- Thank you received: 10
12 Feb 2025 20:20 #321378
by beauxnez
Replied by beauxnez on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thank you for your patience, still error
Note: Using POSIX realtime
MOTION: num_joints is 33, must be between 1 and 16
motmod: rtapi_app_main: Operation not permitted (-1)
./NVEM.hal:5: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:5: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:5: insmod for motmod failed, returned -1
10762
Stopping realtime threads
Unloading hal components
Debug file information:
10762
- Thank you received: 7481
12 Feb 2025 21:31 #321383
Should probably be 3 for normal machines.
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
33 ?MOTION: num_joints is 33, must be between 1 and 16
The following user(s) said Thank You: cakeslob
- LeslieTroyer
13 Feb 2025 18:56 #321459
by LeslieTroyer
Replied by LeslieTroyer on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Im confused --
RPI5 - linuxcnc 2.9.2 (from iso on linuxcnc download page) I get same results on linux on a x86 system
I have a Novusun V5 that I loaded with ....Remora-RT1052-cpp/blob/main/Firmware/remora-rt1052-3.1.3.bin
I've run halcompile on remora-nv in Remora-NVEM-main/LinuxCNC/Components/Remora-nv
i can ping 10.10.10.10
I can tfpt put the python processed config.txt ... I cant load tftpy for some reason so save & use the file created in /tmp
using the remora-nvem-basic when I take it out of E-Stop I get
Bad payload = 0
any suggestions
thanks
Les
Bad payload = 0
any suggestions
thanks
Les
- beauxnez
13 Feb 2025 18:58 - 13 Feb 2025 19:06 #321461
by beauxnez
I deleted xhc-whb04b-6.hal still an error
I no longer have the problem of " MOTION: num_joints is 33, must be between 1 and 16"
I post you the .ini and .hal files in
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Machine configuration directory is '/home/manu/linuxcnc/configs/NVEM'
Machine configuration file is 'NVEM.ini'
INIFILE=/home/manu/linuxcnc/configs/NVEM/NVEM.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtplasmac
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./NVEM.hal
motmod: already exists
./NVEM.hal:6: waitpid failed /usr/bin/rtapi_app motmod
./NVEM.hal:6: /usr/bin/rtapi_app exited without becoming ready
./NVEM.hal:6: insmod for motmod failed, returned -1
8403
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
COORDINATES=X Y Z
8403
Last edit: 13 Feb 2025 19:06 by beauxnez.
- scotta
- Thank you received: 489
13 Feb 2025 19:59 #321473
by scotta
Remora-RT1052-cpp/LinuxCNC/components/Remora-eth at main · scottalford75/Remora-RT1052-cpp · GitHub
For the RT1052 use the remora-eth-3.0 component that is included in that repo.Im confused --
Bad payload = 0
any suggestions
thanks
Les
- scotta
13 Feb 2025 20:06 #321474
by scotta
Looks like you are loading it twice in your hal file. Try removing the 2nd line. From above EMCMOT=motmodloadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD #num_joints=[KINS]JOINTS[TRAJ]SPINDLES
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
The error gives a hint - motmod: already existsI deleted xhc-whb04b-6.hal still an error
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
COORDINATES=X Y Z
8403
- cakeslob
- Thank you received: 280
14 Feb 2025 01:35 #321500
by cakeslob
Hey, can you explain the process that lead you to download the firmware from one repo, but install the component from another? I am trying to identify what is causing people to continue to make this error
remora-docs.readthedocs.io/en/latest/har...Ethernet/rt1052.html
Im confused --
- beauxnez
14 Feb 2025 05:37 - 14 Feb 2025 06:25 #321507
by beauxnez
has anyone made qtplasmac work with a NVEM card?
i modified the .hal file with
[/code]
[code]Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
COORDINATES=X Y Z
Found file(lib): /usr/share/linuxcnc/hallib/qtplasmac_comp.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: qtvcp
No section: 'SHUTDOWN_OPTIONS'
Adding section SHUTDOWN_OPTIONS
Running HAL shutdown script
task: 809 cycles, min=0.000007, max=0.010275, avg=0.009722, 0 latency excursions (> 10x expected cycle time of 0.010000s)
[QTvcp.QTVCP.QT_MAKEGUI][[31mERROR[0m] Trouble looking for handlers in 'qtplasmac_handler': (qt_makegui.py:330)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 308, in _load_handlers
objlist = h(halcomp, widgets, self.PATHS) # this sets the handler class signature
File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 6000, in get_handlers
return [HandlerClass(halcomp, widgets, paths)]
File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__
float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60
TypeError: float() argument must be a string or a real number, not 'NoneType'
[QTvcp][[41mCRITICAL[0m] Aborted from Error Dialog
Qtvcp encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version : 2.9.0~pre1+git20230208.f1270d6ed7
File "/usr/bin/qtvcp", line 508, in <module>
_qtvcp = QTVCP()
File "/usr/bin/qtvcp", line 251, in __init__
window.load_extension(opts.usermod)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 265, in load_extension
methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])
(qtvcp:464)
15446
15483
Last edit: 14 Feb 2025 06:25 by beauxnez.
- LeslieTroyer
14 Feb 2025 08:13 - 14 Feb 2025 08:14 #321518
by LeslieTroyer
of the repositories that looked "hopeful"
Remora-main, and Remora-RT2052-cpp-Main had remora-the-3.0.c
both the same -- neither worked (forgot to incclude that)
and the one listed which also didn't work -- (same error)
I think maybe the 3.0 one I worried was specifically related to the EC500 (all the remora-??? directories under LinuxCNC appear from filenames to be ec500 based
i did hook up a LA1010 to the rs232 port and saw lots of data being transmitted but not much was readable - i then connected the screen that come with the NVEM to the serial port - and now my device its totally unresponsive on the serial port and ethernet port ...
Last edit: 14 Feb 2025 08:14 by LeslieTroyer.
- cakeslob
14 Feb 2025 15:43 #321556
by cakeslob
If your board has the RT1052, refer to the page I linked to, and only install the components/firmware/configurations referred to in the documents. The linuxcnc .hal file configuration doesnt matter if its EC500 or NVEM. The config.txt is important to match with the board.
Time to create page: 0.708 seconds
