1 year 5 months ago #328176 by Daz
I have been using EC300 with Remora for the last four months, and it has been great. Once I got it up and running, I didn't have any problems. You can now get an EC300 with Remora firmware on eBay.
1 year 5 months ago - 1 year 5 months ago #328202 by Murphy
I noticed when looking at encoderS0.position I'm getting no valves. Also no valves when looking at spindle.0.revs in halshow. Could this be causing the issue ? EncoderS0.phase-Z is getting the signal from one of the remora input pins(my encoder index) which both are blinking in halshow when triggered. Should I be seeing the spindle.0.revs displaying a valve in halshow?
Last edit: 1 year 5 months ago by Murphy.
1 year 5 months ago #328209 by cakeslob
normally yes, it will increase, and then during threading i think, there is a reset index command which turns it to 0 i think. during css operation im not sure.
did you end up getting the abz encoder? did you do the spindle.speed-in stuff? monitor that while your doing the css and see if it takes a dive while the speed is changing. the remora.sp0 signal looks exactly as i would expect though, with the speed tapering up or down as the diameter changes.
1 year 5 months ago #328224 by Murphy
Yes iv A and B hooked up to the PV which is working, counting fwd and back. Iv another encoder that came with the machine stock (emco encoder) that I'm using for the Z as it's 24v and hooked straight to an input pin. Yes iv the spindle speed in , in my Hal file same as yours.
1 year 5 months ago - 1 year 5 months ago #328256 by Murphy
When I hook a multimeter up to the vfd 10v in, the voltage physically drops near to Zero if a lot of speed adjustments are done. So I can see now what is happening but iv no idea why the voltage drops so much. It must be something to do with how remora outputs the signal ?
I spent the whole day going through different code with chatgpt and still nothing, it's still dipping. Should I ask this in a general new topic in the forum or is this specific to remora do you think
1 year 5 months ago #328279 by Spyderbreath
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
thanks vp, that will save us a lot of work. we need to archive this shit for the repo or something
darkpheonix - that is good to hear
spyder - this is my WIP remora spindle template (no encoder edition). murphy is also using it. some might be duplicate to what you have now
######################################################################################### # Remora Spindle hal remora_spindle.hal # # this hal file includes the following # - connecting Remora outputs to LinuxCNC motion spindle.0 enable/direction # - connecting spindle signals to LinuxCNC motion spindle.0 pins # - converting the LinuxCNC motion spindle.0.speed-out-abs to signal with scale # - connecting converted LinuxCNC motion spindle.0.speed-out-abs to Remora PWM # ######################################################################################### # conenct LinuxCNC motion spindle.0 on/enable to remora output 01 net spindle-on <= spindle.0.on => remora.output.01 # conenct LinuxCNC motion spindle.0 direction to remora output 02 net spindle-cw <= spindle.0.forward => remora.output.02 # connect spindle signals to LinuxCNC motion spindle.0 net spindle-cmd-rpm <= spindle.0.speed-out net spindle-cmd-rps <= spindle.0.speed-out-rps net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs net spindle-at-speed => spindle.0.at-speed ### Connect and configure spindle PWM/0-10v signal ### ########################################################### # Spindle PWM 0-100 control # converting the LinuxCNC spindle speed output # into a useable output signal for our remora pwm component # - for pwm the math is 100/ [MAX SPINDLE RPM] = gain # 100/(5000rpm) = .02 , the gain is 0.02 ########################################################### # load a linuxCNC scale module, loadrt scale names=scale_to_rpm.0,scale-rpm addf scale-rpm servo-thread # configure spindle rpm to pwm # pwm 100 / max rpm = gain number #setp scale-rpm.gain 0.02 # 100/ rpm (5000) = .02 setp scale-rpm.gain [SPINDLE_0]RPM_GAIN # 100/ rpm (5000) = .02 # connect the LinuxCNC motion spindle.0 speed-out-abs to the pwm scale net spindle-speed-scale spindle.0.speed-out-abs => scale-rpm.in # connect pwm scale output to remora spindle pwm SP.0 net spindle-speed-abs scale-rpm.out => remora.SP.0 # Manual toolchange loadusr -W hal_manualtoolchange net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
I tried this spindle config and I get the following error - ./remora-ec500.hal:79: Ini variable '[SPINDLE_0]RPM_GAIN' not found. Would you or anyone else know what might be wrong and how to fix it?
Time to create page: 1.808 seconds
