- vpomerleau
- Thank you received: 3
07 May 2025 12:22 - 07 May 2025 12:35 #327945
by vpomerleau
Replied by vpomerleau on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Here is what I put in my .Hal file for a standard MPG. This is for EC500 and the switch need to be set to STD MPG on the controller
PS my inputs numbers are not the same as github config.txt, I customize them...
# MPG setup #
setp mux4.0.in0 0.0001
setp mux4.0.in1 0.001
setp mux4.0.in2 0.01
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= remora.input.29 #X10IN
net scale2 mux4.0.sel1 <= remora.input.30 #X100IN
# If your MPG outputs a quadrature signal per click set x4 to 1
# If your MPG puts out 1 pulse per click set x4 to 0
setp encoder.0.x4-mode 0
# For velocity mode, set to 1
# In velocity mode the axis stops when the dial is stopped
# even if that means the commanded motion is not completed,
# For position mode (the default), set to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take
setp joint.0.jog-vel-mode 1
setp joint.1.jog-vel-mode 1
setp joint.2.jog-vel-mode 1
setp axis.x.jog-vel-mode 1
setp axis.y.jog-vel-mode 1
setp axis.z.jog-vel-mode 1
#setp joint.3.jog-vel-mode 1
#setp joint.4.jog-vel-mode 1
#setp joint.5.jog-vel-mode 1
setp axis.a.jog-vel-mode 1
setp axis.b.jog-vel-mode 1
setp axis.c.jog-vel-mode 1
# The output from the mux4 is sent to each axis jog scale
net mpg-scale <= mux4.0.out
net mpg-scale => joint.0.jog-scale => axis.x.jog-scale
net mpg-scale => joint.1.jog-scale => axis.y.jog-scale
net mpg-scale => joint.2.jog-scale => axis.z.jog-scale
#net mpg-scale => joint.3.jog-scale => axis.a.jog-scale
#net mpg-scale => joint.4.jog-scale => axis.b.jog-scale
#net mpg-scale => joint.5.jog-scale => axis.c.jog-scale
# The MPG inputs
net mpg-enc-a encoder.0.phase-A <= remora.input.21
net mpg-enc-b encoder.0.phase-B <= remora.input.22
# The Axis select inputs
net mpg-x axis.x.jog-enable <= joint.0.jog-enable <= remora.input.23
net mpg-y axis.y.jog-enable <= joint.1.jog-enable <= remora.input.24
net mpg-z axis.z.jog-enable <= joint.2.jog-enable <= remora.input.25
#net mpg-a axis.a.jog-enable <= joint.3.jog-enable <= remora.input.26
#net mpg-b axis.b.jog-enable <= joint.4.jog-enable <= remora.input.27
#net mpg-c axis.c.jog-enable <= joint.5.jog-enable <= remora.input.28
# The encoder output counts to the axis. Only the selected axis will move.
net encoder-counts <= encoder.0.counts
net encoder-counts => joint.0.jog-counts => axis.x.jog-counts
net encoder-counts => joint.1.jog-counts => axis.y.jog-counts
net encoder-counts => joint.2.jog-counts => axis.z.jog-counts
#net encoder-counts => joint.3.jog-counts => axis.a.jog-counts
#net encoder-counts => joint.4.jog-counts => axis.b.jog-counts
#net encoder-counts => joint.5.jog-counts => axis.c.jog-counts
# MPG setup #
# The MPG inputs
Last edit: 07 May 2025 12:35 by vpomerleau.
The following user(s) said Thank You: cakeslob
- cakeslob
- Thank you received: 280
07 May 2025 23:43 #327966
by cakeslob
thanks vp, that will save us a lot of work. we need to archive this shit for the repo or something
darkpheonix - that is good to hear
spyder - this is my WIP remora spindle template (no encoder edition). murphy is also using it. some might be duplicate to what you have now
# Remora Spindle hal remora_spindle.hal
# this hal file includes the following
# - connecting Remora outputs to LinuxCNC motion spindle.0 enable/direction
# - connecting spindle signals to LinuxCNC motion spindle.0 pins
# - converting the LinuxCNC motion spindle.0.speed-out-abs to signal with scale
# - connecting converted LinuxCNC motion spindle.0.speed-out-abs to Remora PWM
# conenct LinuxCNC motion spindle.0 on/enable to remora output 01
net spindle-on <= spindle.0.on => remora.output.01
# conenct LinuxCNC motion spindle.0 direction to remora output 02
net spindle-cw <= spindle.0.forward => remora.output.02
# connect spindle signals to LinuxCNC motion spindle.0
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
### Connect and configure spindle PWM/0-10v signal ###
# Spindle PWM 0-100 control
# converting the LinuxCNC spindle speed output
# into a useable output signal for our remora pwm component
# - for pwm the math is 100/ [MAX SPINDLE RPM] = gain
# 100/(5000rpm) = .02 , the gain is 0.02
# load a linuxCNC scale module,
loadrt scale names=scale_to_rpm.0,scale-rpm
addf scale-rpm servo-thread
# configure spindle rpm to pwm
# pwm 100 / max rpm = gain number
#setp scale-rpm.gain 0.02 # 100/ rpm (5000) = .02
setp scale-rpm.gain [SPINDLE_0]RPM_GAIN # 100/ rpm (5000) = .02
# connect the LinuxCNC motion spindle.0 speed-out-abs to the pwm scale
net spindle-speed-scale spindle.0.speed-out-abs => scale-rpm.in
# connect pwm scale output to remora spindle pwm SP.0
net spindle-speed-abs scale-rpm.out => remora.SP.0
# Manual toolchange
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
The following user(s) said Thank You: Spyderbreath
- Spyderbreath
- Thank you received: 9
08 May 2025 00:49 #327970
by Spyderbreath
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Wonderful. Yea, I don't think I would of gotten that spindle config. Thanks.
And I think my next and maybe final question for now is when uploading the .txt file to the controller, does the upload script need to be run in a virtual environment or can it be run from a standard console?
I ask thinking about changing to the DMAstepgen from the basic.
- cakeslob
08 May 2025 03:02 #327976
by cakeslob
im not sure, ive only ever use the regular terminal, but im not using the debian linuxcnc image
- cakeslob
08 May 2025 15:46 #328009
by cakeslob
dammit spyder i thought i had more time before you would start asking about qtdragon
im working on a thing for easy GUI switching, but in the mean time you can use this as a reference because i know it works and its pretty close to what the config is you want.
github.com/Expatria-Technologies/remora-...hal/remora-flexi.ini
github.com/Expatria-Technologies/remora-...figSamples/flexi-hal
- Spyderbreath
08 May 2025 16:44 #328015
by Spyderbreath
Sorry, didn't mean to offend. Take your time as in the end I will be needing the "thing for easy GUI switching".
Tried it and instantly end up with an error.
flexi: dlopen: /usr/lib/linuxcnc/modules/flexi.so: cannot open shared object file: No such file or directory
I tried it 2 ways by copying the .ini and .hal files into the existing qtdragon config and by copying the entire flexi config file and running it from there and same error.
- cakeslob
08 May 2025 16:53 - 08 May 2025 16:54 #328016
by cakeslob
lol not offended, you move to fast, i was trying to stay one step ahead. but no you cant just load it as is, but its a very similar config as to what you want in the end. make a copy of your config folder, and replace a bunch of stuff. Specifically the [DISPLAY] section of the config, then there might be some probe related macro files and qtdragon related files. the remora-flexi.hal , dont touch i think. but there are some qtdragon hal files in there
Last edit: 08 May 2025 16:54 by cakeslob.
- Spyderbreath
08 May 2025 17:15 #328019
by Spyderbreath
Figured it out with the help of Hakan! Filled me in on what I was not getting. Working now, or at least far more complete than what I have ever had before.
www.forum.linuxcnc.org/qtvcp/56093-movin...s-to-qtdragon#328018
Thank you!
Thank you!
- Murphy
- Thank you received: 5
09 May 2025 14:42 - 09 May 2025 15:39 #328076
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
@caskeslob. When I'm in CSS mode and moving the X axis . In halscope the Remora.sp signal looks like it's tapering , is it supposed to this? You can hear the spindle in the background slowing down with every adjustment . I'm moving in 10mm jogs .
youtube.com/shorts/wCQEtX8jdlg?si=56bFTHS2TniANqbB
Not in CSS mode
youtube.com/shorts/3FCbzGDeuUc?si=U3O0NyMvfS-R4K8-
Not in CSS mode
Last edit: 09 May 2025 15:39 by Murphy.
- cakeslob
10 May 2025 03:10 #328119
by cakeslob
im not an expert but i think thats exactly what its supposed to look like (rpm changing as diameter changes). assuming those portions that are the straight lines are in between jog moves. I didnt see (or hear) any weird spindle speed drop outs like before thought. i am assuming you figured out the issue?
Time to create page: 0.981 seconds
