- aDm1N
- Thank you received: 24
05 May 2025 18:01 #327770
by aDm1N
Replied by aDm1N on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I started from scratch with the standard examples. I made some adjustments, and now Remora Input 4 is responding. However, this only happens when the emergency shutdown is disabled in the GUI. So, Remora probably only starts working after that.
- DarkPhoinix
- Thank you received: 6
05 May 2025 18:24 - 05 May 2025 20:17 #327773
by DarkPhoinix
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'm starting to go crazy, I don't understand what to do anymore I see people using files for ec500 on nvemV5 which files are correct for nvem V5 rt1052?
this github.com/scottalford75/Remora-RT1052-c...ec500-rt1052-DMA.txt
or github.com/scottalford75/Remora-RT1052-c...xCNC/nvem-rt1052.txt
Excuse me if I may, but wouldn't it be better to create these posts to create a bit of order?
Remora - ethernet NVEM rt1052 cnc board
Remora - ethernet NVEM stm32 cnc board
Remora - ethernet EC300 cnc board
Remora - ethernet EC500 cnc board
forum.linuxcnc.org/18-computer/44828-rem...ard?start=410#251651
Last edit: 05 May 2025 20:17 by DarkPhoinix.
- Spyderbreath
- Thank you received: 9
05 May 2025 18:51 #327776
by Spyderbreath
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
You said "this only happens when the emergency shutdown is disabled in the GUI." So does this mean that there is a bug in the estop or just not quite the correct configuration for it to fully function?
- Spyderbreath
05 May 2025 19:01 - 05 May 2025 19:07 #327777
by Spyderbreath
The nvem-rt1052.txt is the one you want to use for the NVEM v5 to upload to the unit. Then the remora-ec500.hal and remora-ec500.ini, as from what I have been lead to believe the .hal and .ini files are more or less universal among the 3 units. Following that path, I have gotten a few inputs to work and while not fully tested with motors, the X Y and Z seem to be outputting pulse and direction signals when g-code is run.
edit: I agree that it would be nice if all this was split between the boards, it can get extremely confusing very fast.
Last edit: 05 May 2025 19:07 by Spyderbreath. Reason: added a comment
- DarkPhoinix
05 May 2025 20:06 #327781
by DarkPhoinix
Does this work for you with steppers? Could you show me a little video? Internal photos of the board?
github.com/scottalford75/Remora-RT1052-c...CNC/remora-ec500-DMAThe nvem-rt1052.txt is the one you want to use for the NVEM v5 to upload to the unit. Then the remora-ec500.hal and remora-ec500.ini, as from what I have been lead to believe the .hal and .ini files are more or less universal among the 3 units. Following that path, I have gotten a few inputs to work and while not fully tested with motors, the X Y and Z seem to be outputting pulse and direction signals when g-code is run.
- DarkPhoinix
05 May 2025 20:27 #327782
by DarkPhoinix
Hi, what board do you have? with what microcontroller?This is my E-stop in my .hal file.
net nvem-estop <= estop-latch.0.fault-in <= remora.input.14
It's just a switch. Once the input is triggered it should work.
- Spyderbreath
05 May 2025 20:43 #327783
by Spyderbreath
Unfortunately I do not have this unit wired in yet. I got this to replace a complete POS usb board that shipped with the mill and never worked from the moment it came out of the crate. (no direction change on x and y and no spindle control), I am trying to get everything working on the bench first just in case I might need to reflash the unit. Save me the hassle of having to completely unwire and rewire the unit if something turns up wrong.
I used the remora-rt1052-basic version because that was what was recommend to me.
Sorry I'm not able to be more helpful as I am very new to both LinuxCNC and this Remora stuff.
- DarkPhoinix
05 May 2025 21:06 #327789
by DarkPhoinix
why you take some files from this path?
- DarkPhoinix
05 May 2025 22:49 - 05 May 2025 22:50 #327797
by DarkPhoinix
I have to load all from:
and upload this to NVEM:
I don't understand well,if it is stepper timing related you need to load the DMA stepgen config and adjust your step timing accordingly
Last edit: 05 May 2025 22:50 by DarkPhoinix.
- cakeslob
- Thank you received: 280
05 May 2025 23:00 - 05 May 2025 23:03 #327798
by cakeslob
Alright its starting to look like the inmates are running the asylum. Everyone just hold on for a moment, breath in and out, and cool our heads. I know english or linuxcnc isnt everyones first language, but it looks like everyone is working off each others confusion, and you guys are spiraling out. I think there are some core concepts we arent all understanding completely. Its clear that you guys are smart people, so lets hold on for a moment and regroup, and always read the manual. If you atre getting frustrated, just start from page one and read. If there are things getting lost in translation on the documents, letting us know would be great, and we can change some of the wording. I know the docs arent perfect, but the core concepts are the same for the whole of remora.
Also, if its a remora specific question, it is best to ask in the thread. remora isnt really a big wide linuxcnc thing, it makes it harder to find your thread.
Last edit: 05 May 2025 23:03 by cakeslob.
The following user(s) said Thank You: DarkPhoinix
Time to create page: 0.651 seconds
