1 year 2 months ago #333921 by Murphy
Anyone know how to setup two inputs to trigger the motion-probe.input?
I have a tool height setter and probe. I can only link one at a time it won't allow two input pins to trigger the motion-probe-input. I tried or2 but neither will trigger when I use or2
1 year 2 months ago - 1 year 2 months ago #333946 by Murphy
My tool setter in NC , probe is NO.
So I'm using the remora.input11.not to invert the pin. But that dosnt seem to work with or 2.0.
When I use the normal remora.input.11 pin the prob works as it should triggering the motion.probe signal. Tool setter when pressed triggers only the or2 in.
Addf or2.0 servo-thread
Net toolsetter remora.input.11.not or2.0.in0
Net Probe_tool remora.input.12
or2.0.in1
Net probes or 2.0.out motion.probe-input
Is there a way to get this to work other than a relay
^^^^ I got this to work with classic ladder
Last edit: 1 year 2 months ago by Murphy.
1 year 1 month ago - 1 year 1 month ago #334281 by Murphy
Last edit: 1 year 1 month ago by Murphy.
1 year 1 month ago #334289 by Benb
Try this
# Load realtime Components and their counts
loadrt not  count= 1
loadrt or2  count= 1
# Add functions to threads
addf not.0    servo-thread
addf or2.0    servo-thread
# Connect Pins
net toolset         remora.input.11   not.0.in
net inv.toolset    not.0.out             or2.0.in0
net toolprobe    remora.input.12   or2.0.in1
net probe          or2.0.out              motion.0.probe-input
The following user(s) said Thank You: Murphy
1 year 1 week ago #336726 by sconisbee
Replied by sconisbee on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good Evening,
I'm relatively new to LinuxCNC having come from Mach 3 on mills previously.  Having found mach3 limited for lathes I have moved over to LinuxCNC.  I have been/have converted an old Boxford 240 TCL to run on new steppers, and LinuxCNC running on a Pi5 connected to an ec300 running the remora firmware.
Everything in general is working fine, except the spindle encoder.  Annoyingly, it is not a quadrature encoder.  It is a 100ppr slotted disk with an additional index pulse.  Currently, this is feeding directly into the Pi5, which is reading the 100ppr but missing the index.
So, my plan is to move the encoder and index over to the ec300.  While i understand that the ec300 has a dedicated index input, I am unsure on using an encoder with remora.  I've read the docs, and have run through this thread but my head is spinning trying to get things straight.
Does the EC300 have the ability for a hardware encoder?  if not, software would work too, I'm just not sure how to set up the encoder component as I do not have a B phase.
On the hardware side, I'm going to have to work out some electronics as the encoder as it stands is running on 3.3v with schmitt triggers for conditioning.  So I will have to come up with something to level shift this to 24v.
Any help that could be given on the remora side of things would be greatly appreciated.
1 year 1 week ago #336781 by andypugh
There shouldn't be any problem using an encoder with only A and Z channels. I assume you are using the LinuxCNC software encoder?
If you set counter-mode it should count, but only up, never down. (but you probably already did this).
You seem to be saying that counter-mode prevents index reset from working? I am almost 100% sure that isn't the case.
There may be a not-insuperable problem in your wiring or HAL logic.
Time to create page: 0.216 seconds
