1 year 3 months ago #331369 by tuxcnc
I originally had this running on a cheap eBay BOB using the denford drivers. When I switched over to the EC500 I could not get the driver working correctly with the EC500. After many attempts with different IC and board configurations I gave up trying to use the denford drivers and bought DM556T drivers. Still on the denfords motors.
The EC500 has strange "differential" outputs 3.3 V.
I don't know any motor controller that has such inputs, but some 5-24 V work.
If problem, I use PC817 optocouplers without any resistors.
They have poor parameters, but only these want to work for me ...
1 year 3 months ago - 1 year 3 months ago #331376 by Murphy
Thanks tuxcnc, ya I couldn't get it to work. The final IC's I used was a 26ls32 to single end the differational signal. Into a 74htc14 to boost the signal to 5v. And then into a uln2003 IC to pull down the 12v denford pulses. I was getting a lot of noise. I tried pulling up/down resistors and capacitors to try and negate it. But didnt work. These dm566 drivers seem to work fine with the ec500. I'll have to do some more testing.
Last edit: 1 year 3 months ago by Murphy.
1 year 3 months ago #331528 by Murphy
Anyone else here using the RT1052 ec500 with CSS??
1 year 3 months ago #332043 by Thayloreing
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello everyone,
I'm trying to use the NVEM V5 board with LinuxCNC, running the Remora RT1052 firmware.
✅ What has already been done:
1. The Remora RT1052 source code was downloaded directly from the official GitHub repository.
2. Inside the remora-rt1052/source/ folder, a new folder named default was created.
3. Inside the default folder, two files were created and configured:
defaultConfig.c
defaultConfig.h
4. These files were manually edited to define fixed pins for the NVEM V5, with the following configuration:
4 axes (X, Y, Z, A)
2 encoders
The remaining I/O as digital inputs and outputs
5. The project was successfully compiled using MCUXpresso IDE, generating a .bin file.
6. The .bin file was flashed correctly to the NVEM V5 using pyOCD, with no errors.
7. On the computer, the network interface was configured with a static IP, and the board responds to ping.
⚠️ What has not been done:
❌ The upload_config.py script was not used (the NVEM V5 does not support it).
❌ No remora.conf file was used.
❌ The HAL pins have not yet been defined in the .ini and .hal files, since the pins are fixed in the .bin.
❓ Current issue:
Even after all the steps above, LinuxCNC does not enable the machine (emergency state remains active). The NVEM board does not seem to start communication with the host, even though the IP is correctly configured and it responds to ping.
❓ Questions:
1. Is there any minimum requirement in the .hal or .ini files for LinuxCNC to properly initiate communication with fixed firmware?
2. What else could prevent the machine from exiting emergency, even with the correct fixed .bin?
3. Has anyone successfully used the NVEM V5 with fixed pins in the firmware, without using remora.conf?
1 year 3 months ago #332084 by scotta
Hi, please share your LinuxCNC hal and ini files. Is the remora ethernet component loaded?
github.com/scottalford75/Remora-RT1052-c...omponents/Remora-eth
1 year 3 months ago - 1 year 3 months ago #332567 by michaelvdberghe
Replied by michaelvdberghe on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
hi, i'm new to this cnc building and followed your guide on page 165 and was able to flash the firmware to the ec500v5 board but i'm a bit stuck at the moment.
i'm tring to complete step 8 install eth component but i have abolutely no clue what you mean with this step nor where to find the folder.
Last edit: 1 year 3 months ago by michaelvdberghe.
Time to create page: 2.618 seconds
