1 year 5 months ago #328755 by scotta
is there a way to download previously uploaded nvem-rt1052.txt from NVEM?
Unfortunately, no. It's a one way process.
The following user(s) said Thank You: DarkPhoinix
1 year 5 months ago #328756 by DarkPhoinix
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Warning: Spoiler!
I wanted to give it a high pulse/rev value to have a higher resolution, but I couldn't get precision in long movements. I put your values ​​and after a slight change of scale everything went well!
Thank you very much.
Isn't there a way to calculate SCALE in a precise way? Unfortunately the seller of my steppers and Drivers doesn't give me datasheets and it's really difficult to set them up properly, except trying random values. I also tried with math but nothing I couldn't get low error values ​​Scale=scale_set*Dist_measured/Dist_Insert
1 year 5 months ago #328758 by DarkPhoinix
Warning: Spoiler!
Thanks a lot, I'll do some bck just to be safe.
Thank you for doing this amazing job and allowing me to use linuxcnc with my low budget hardware!
1 year 5 months ago #328759 by scotta
I'd always recommend calculating the joint SCALE based on the hardware. ie steps per revolution of the stepper motor and then the leadscrew pitch etc. If the actual movement achieved is not correct I'd be suspicious of lost steps, especially if micro stepping.
1 year 5 months ago - 1 year 5 months ago #328817 by DarkPhoinix
the seller does not give me any documentation. The only things I have are:
Driver
Pulse/rev SW5 SW6 SW7 SW8 ----------- ----- ----- ----- ----- Default    on on on on 800         off on on on 1600       on off on on 3200       off off on on 6400       on on off on 12800     off on off on 25600     on off off on 51200     off off off on 1000       on on on off 2000       off on on off 4000       on off on off 5000       off off on off 8000       on on off off 10000     off on off off 20000     on off off off 40000     off off off off
Stepper: Step angle1.8∘±5%
in the TXT file i have set:
    "Thread": "DMA",     "Type": "DMAstepgen",         "Comment":            "Y - Joint 1 step generator",         "Joint Number":        1,         "Step Pin":        "P1_24",         "Direction Pin":    "P1_31",         "Step Length":        7,         "Step Space":        2
Frame:
SFU2005 and SFU1605 ball screws Repetitive positioning accuracy: 0.05mm
Last edit: 1 year 5 months ago by DarkPhoinix.
1 year 5 months ago - 1 year 5 months ago #328827 by Murphy
@ Thayloreing Looks like you have no Comms with the board. Which could be why you can't upload the config to the board. Look back in the posts there is steps there to change the IP address for the board to 10.10.10.10.
@scotta, have you tested the v5 boards with CSS ?. I'm having issues only in CSS mode. Signal keeps dropping when there is speed changes during CSS. Voltage newly drops to zero, once speed changes stop it goes to the required speed. I'm thinking it could be the 0-10v chips on the EC500's.
Last edit: 1 year 5 months ago by Murphy.
Time to create page: 1.855 seconds
