1 year 5 months ago #328493 by Murphy
Regarding my milling machine and setting up the EC500.
My denford mill is using 12v drivers
​​that need to sink the 12v to ground to move the axis.
​​​i tried a bc537 transistor to try and switch the 12v to ground. I originally had this working with a cheap bob. But it seems the ec500 outputs are to low to drive the gate. I'm measuring 3.8v on the ec500's outputs.
I also tried a IRLZ44n mosfet but that's also the same I can't switch the gate. Both circuits had pull up and down resistors. If I connect 5v straight to the gate (330omh resistor) I can switch the gate and pulse the drive. So I'm thinking the outputs of the EC500 are just not strong enough.
The IC in the ec500 is the am26ls31. If I connect the differential outputs to a am26ls32 will that restore a 5v stronger signal?
1 year 5 months ago #328499 by cakeslob
hey murph, i think scott said the outputs were just optocouplers or something like that, see if you can filter through his recent posts,
pheonix, like spyder said its based on application, but start with like 800-1600 and if you get following errors its too high
The following user(s) said Thank You: Murphy
1 year 5 months ago - 1 year 5 months ago #328511 by DarkPhoinix
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Warning: Spoiler!
Thanks for reply,
I have set 12800 and testing some gcode only with Y working.
I don't want to cause problems when all the stepper and spindle are physically working.
Last edit: 1 year 5 months ago by DarkPhoinix.
1 year 5 months ago #328662 by Thayloreing
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Please, I've been trying for months without success. Everything seems to be fine, but I can't compile it onto the board. I'm using v5 of the cloud. I have no idea what it could be. I see that everyone follows the steps and it works. However, I even had a lot of trouble installing pyocd, but with a lot of effort I finally managed to do it. Please, can someone tell me what I'm doing wrong?
1 year 5 months ago #328703 by Murphy
Try been in the directory where the file is located. Before you run pyocd. Are you able to ping the board. 10.10.10.10 ??
1 year 5 months ago - 1 year 5 months ago #328706 by Thayloreing
  Good afternoon, I think I managed to do what you asked me, but without results, still with the same error. Could it be my pyocd installation? I've tried with other versions of Debian, but always the same problem.
Last edit: 1 year 5 months ago by Thayloreing.
Time to create page: 2.018 seconds
