1 year 5 months ago #328934 by scotta
Hi DarkPhoinix,
The Step Length and Step Space need to be integers / whole numbers. So go with 5 and 3.
The following user(s) said Thank You: DarkPhoinix
1 year 5 months ago - 1 year 5 months ago #329356 by PopBang
Hey guys, I'm pretty new to all this coding jazz, but I've fumbled my way through a bit so far. I'm using a NVEM V2 board with the NVMPG to control a RongFu RF31 i have retro fitted with some stepper/servos. So far i can move the X Y Z axes accurately using the key board and the NVMPG, I can also select axes with the NVMPG and I'm seeing all the inputs work in the Hal Configuration. But now I'm at a loss at how to modify the Hal file to get those inputs to function, especially the estop. I'm using a N/O estop switch and it's switching remora.input.04 to false (.04.not to True) when hit.
What do i need to add to the Remora-nvem.hal file to make it work?
Or does any one have an already working .Hal file for the NVEM V2 with limit switches and other typical milling functions i could look over?
File Name: remora-nvem.hal
File Size:2 KB
Last edit: 1 year 5 months ago by PopBang. Reason: bad layout
1 year 4 months ago #330233 by scotta
@Murphy,
I've made some code changes which may help with the spindle issues. Would greatly appreciate your feedback.
github.com/scottalford75/Remora-RT1052-c...t1052-3.1.4.beta.bin
The following user(s) said Thank You: Murphy
1 year 4 months ago - 1 year 4 months ago #330237 by Murphy
Thank you scotta, Im back early next week, I'll try it then and let you know.
Last edit: 1 year 4 months ago by Murphy.
1 year 4 months ago - 1 year 4 months ago #330518 by tuxcnc
I can't drive EC500 spindle encoder to work.
(The counter works properly, but index not. I can use encoder's index output as ordinary I/O, but this not satisfied me due to delays)
I suspect, this never will work, because the used code is wrong way.
I'm developing similar project (but only spindle support) on STM32F103, and my code seems works properly.
Here you are most important fragments:
[code]//******************************************************** This is a fragment of code from other project Not for copy/paste, only for explanation //******************************************************** // EC500 side // fb. prefix means variables will send from EC500 to hal component struct fbPacket {     float raw_encoder;     float encoder_latched; } fb = { 0.0, 0.0 }; fb.raw_encoder = encoder.getCount(); void index_ISR1() {        // interrupt handler   fb.encoder_latched  = encoder.getCount(); } //******************************************************** // Hal component side // fb. prefix means variables received from EC500 // index_ena is i/o hal pin for connect to spindle.0.index_enable // pos_scale is hal input pin // period is LinuxCNC global variable // pos and vel are hal output pins // Not need anything else for synchronising spindle float old_pos; float latched_enc; float encoder_latched_old; float delta_pos; float delta_time; struct FB {     float raw_encoder;     float encoder_latched; } fb = { 0.0, 0.0 };             if  ((encoder_latched_old != fb.encoder_latched) && (index_ena)) {             latched_enc = fb.encoder_latched;         old_pos = (fb.raw_encoder - latched_enc);             index_ena = false;             }             encoder_latched_old = fb.encoder_latched;    pos = (fb.raw_encoder - latched_enc) / pos_scale;    delta_pos = pos - old_pos;    old_pos = pos;    delta_time = period * 1e-9;    vel = delta_pos / delta_time;     //********************************************************
[/code]
Last edit: 1 year 4 months ago by tuxcnc. Reason: edit the code
1 year 4 months ago #330531 by scotta
Hi, which module have you been trying to use? The software Encoder module or the QDC module? Both support the index pulse detection and encoder count latching so LinuxCNC can acquire the index position count.
Time to create page: 2.643 seconds
