- Thank you received: 48
- MX_Master
4 years 3 months ago #248098
by MX_Master
Replied by MX_Master on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Naming is the biggest problem of programming
- scotta
- Thank you received: 489
4 years 3 months ago #248149
by scotta
A short video on the EC500.
The following user(s) said Thank You: tommylight, wazza77, kwarup
- kwarup
- Thank you received: 9
4 years 3 months ago #248167
by kwarup
Replied by kwarup on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Scot, EC500 will have better frequency more than 40khz ?
- scotta
4 years 3 months ago #248193
by scotta
The default is 40khz but in the config and LinuxCNC loadrt command it is possible to increase the base thread frequency. Capped at 120khz at the moment.
MX_master's posts has got me working on a DMA step generator which should get the step rate significantly higher, I hope.
The following user(s) said Thank You: kwarup
- Murphy
- Thank you received: 5
4 years 3 months ago #248200
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
This is great work. Currently doing a Denford mill retrofit with parallel cards. I also have an emco little CNC waiting to get converted. Is it possible to get these to work with encoder inputs? Ie a toolchanger?.
- scotta
4 years 3 months ago #248201
by scotta
For 3D printer controllers, Remora has encoder support. Both in software and QEI for high speed. This is a feature that could be added to the NVEM and EC500 versions.This is great work. Currently doing a Denford mill retrofit with parallel cards. I also have an emco little CNC waiting to get converted. Is it possible to get these to work with encoder inputs? Ie a toolchanger?.
Time to create page: 0.245 seconds
