4 years 3 months ago #247778 by kevin_allein
Replied by kevin_allein on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi all, I tried to check the entire thread, but unless I missed it, is there no intro, how to copy the tool setup ? I installed STM32CubeIDE, but any pointers, how to import the project and compile ?
I am pretty experienced with some development tools, however have never used the STM environment.
4 years 3 months ago #247780 by fintech
I used Scott's precompiled bin file and used ST-Link software. I was able to get it up in a few minutes.
www.st.com/en/development-tools/stsw-link004.html
4 years 3 months ago #247795 by scotta
Hi, as fintech has mentioned. The easiest is to use the pre-compiled firmware bin file. However, if you would like to compile from source:
1. Clone the Github repo
2. Open STMCubeIDE
3. File -> Open Projects from File System
4. Select the cloned repo directory
5. Click Finish
6. Remora-NVEM should now be visible in the Project Explorer
7. The source code is under Core/Src and Core/Inc
8. Clicking the build button (Hammer) will compile the code. Use the release version as the debug version will have a lot of overhead that will crash the base thread.
4 years 3 months ago #247796 by scotta
NVEM developers made a hardware planning mistake, so we can't output pulses directly using STM's timers. But yea, we can use timers + DMA to write data to the GPIO BSRR registers. One problem here - we can use only timer 1 and 8 to do the trick because only those timers has a transfer requests for the DMA2 controller. DMA1 controller has no access to the GPIO BSRR registers. So after a first look we have just 2 stepdir channels for the high speed pulses generation. After second look I found out that we can use timer 1 and 8 for the other stepdir channels too. To do that we must use other timers to generate softly (inside IRQ handler) unused DMA transfer requests for the timer 1 and 8. As a pulses counter we using DMA transfer counter.
And now we got two methods:
FAST (timer1,8 -> DMA2 request -> DMA2 stream -> GPIO BSRR) - up to 1 MHz of pulses;
SLOW (timer3,4,6,7 -> IRQ handler -> DMA2 request -> DMA2 stream -> GPIO BSRR) - up to 400 KHz of pulses.
I can't show the sources because I'm using some parts of the code for the business. But this short description will help to understand the tricks.
Thanks MX_master! Shame your code is not open source but enough pointers to get me thinking. I'm guessing you are using a ring buffer or similar to hold the step pattern?
I see a slight difference in the requested frequency and the output. Is this due to the underlying DMA frequency or because it is a digitally synthesised frequency?
4 years 3 months ago #247806 by MX_Master
Replied by MX_Master on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
DMA stream works in circular mode. And yea, for each channel we must have a buffer of states for the GPIO BSRR register.
About inaccurate values of frequency.. It's all about timer's prescaler (16bit) and period (16bit) limits. Inaccurate duty cycle values - it's DMA bus latency related issue.
4 years 3 months ago #248085 by scotta
The number of Ethernet controllers supported by Remora firmware is increasing  . The Digital Dream EC500 is now 99% working with just the NVMPG and spindle analogue to resolve.
The owner of the board below will start testing soon. This board I hope (fingers crossed) will have the spindle analogue working as it uses the same components as the NVEM v3 I have. The EC500 board that I received looks to be an older version using a op amp for the analogue out.
With the number of boards increasing I'm proposing to change both the repo and the naming of the LinuxCNC component.
Propose to change / new repo to Remora-Novusun and have sub directories for the NVEM and EC500 etc.
The LinuxCNC Ethernet component to change to Remora-nv
Would this cause to many issues for people?
The following user(s) said Thank You: tommylight, MX_Master, kwarup
Time to create page: 0.404 seconds
