- Thank you received: 234
Hi, did you have the board running with the example config included? It's known to work and the best place to start to ensure that all the hardware is talking correctly. I'd then move on to your own HAL and INI config.Hey there,
my attempts to reproduce the NVEM-linuxcnc configuration ends up with an error message, saying there would be a positioning error for the motors.
Error message in the terminal says "emc/task/taskintf.cc 942 : error on joint 0" followed by the command number.
I've been looking through the HAL-files but couldn't find a thing.
The board gets detected and i can see the different I/O-pins. Also i am able to observe any inputsignals trough this pins.
My Linuxcnc is running on an Desktop in version 2.8.4. [Debian 10 (New installation)] all configurations for the board and L-cnc made like in Scott's video.
Any idea how to solve this ?
Not a strange behaviour, the firmware does not keep / store the DDS position accumulator values during a power off. The LinuxCNC component adds the difference between two position reads (incremental) to the last calculated position value. So effectively you are resetting the next position count back to zero.@Scotta
I am using Remora for a bench prototype with the NVEM v2 board with 6 axis and 3 motors. I am using the 1.0.0 release.
I discovered the following strange behavior of the driver card:
0. Start LinuxCNC
1. Enable drivers
2. Jog a little bit
3. Power off card (disconnect 24V)
4. Power on card
5. Unset EStop
Now the commanded position and the position feedback from Remora differs (about 0.1 - 0.05mm).
This is not corrected, because the EStop is active.
Now, if I enable the drivers, the motor moves a little bit. LinuxCNC corrects the position error.
What could be the reasons for this? Why does the position feedback change after power on of the card?
Are maybe the PID values wrong?
I hope I described the problem to be understandable (image missing /media/kunena/emoticons/smile.png
