Thank you for the clarification. It would be great if this would not happen.
@Scotta
I am using Remora for a bench prototype with the NVEM v2 board with 6 axis and 3 motors. I am using the 1.0.0 release.
I discovered the following strange behavior of the driver card:
0. Start LinuxCNC
1. Enable drivers
2. Jog a little bit
3. Power off card (disconnect 24V)
4. Power on card
5. Unset EStop
Now the commanded position and the position feedback from Remora differs (about 0.1 - 0.05mm).
This is not corrected, because the EStop is active.
Now, if I enable the drivers, the motor moves a little bit. LinuxCNC corrects the position error.
What could be the reasons for this? Why does the position feedback change after power on of the card?
Are maybe the PID values wrong?
I hope I described the problem to be understandable (image missing /media/kunena/emoticons/smile.png
