4 years 1 month ago - 4 years 1 month ago #253143 by MX_Master
In some cases SPI flash can be not readable/writable when it soldered to the PCB. In this cases we must to solder it out. But I have a feeling that SPI flash is encrypted and the bootloader stores the keys for the decryption. Bootloader must be not readable (due to copyright purposes). So going by the SPI flash way can be a bad idea.
By the way, we have a button on the PCB. I guess it makes something with a boot sequence. When the ST-Link is connected and the button is pressed on boot, additional LED is lighting. In other cases this LED is off (see the photos).
A magic "IC" chip is also here (see the photos).
Last edit: 4 years 1 month ago by MX_Master.
4 years 1 month ago #253184 by Bari
Why the risk with these boards is them actually having the flash "encrypted and the bootloader stores the keys for the decryption" if not, yet but easily changed in the future by the maker. Can you change the keys or remove them after on the RT1050? Can you return the rt1050 to a blank slate after they have set the keys? We don't care about cracking their binary firmware, just replacing it.Do you really want to spend this much time on a port if other lower cost boards are available?
4 years 1 month ago #253198 by scotta
Interesting to see the NVEM v2.1 also has the push button and voltage monitoring circuit and that there appears to be a boot sequence.
I feel a bit bad that people went out an purchased an NVEM thinking that they could convert it for use with LinuxCNC.
Will give this a good go to see if we can connect to the MCU, as you said we don't really care about the existing firmware, just being able to replace it.
4 years 4 weeks ago - 4 years 4 weeks ago #253231 by epineh
Just thinking out aloud here, is there a processor that is more suited to Remora ? I don't claim to be an Electronic Engineer but I have a bit of experience in PCB design and layout, I have built my own servo drives for several of my own machines using Elm Chan firmware, first incarnation worked for 9 years without failure.
From what I've seen these controllers aren't particularly hi-tech, buffering, optos, packaged fairly nicely. If there is a processor that could be used that is readily available at the moment I would be happy to do a prototype layout and get PCB's built for testing. I've heard the STM blue pills and the like are very cheap but also there are a lot of fakes.
We would have to keep in mind being an open source project that people can replicate at home, so possibly something like an STM blue pill/esp32 whatever that can be socketed onto a through hole board without SMD tooling requred.
Last edit: 4 years 4 weeks ago by epineh.
4 years 4 weeks ago #253242 by MX_Master
"NVEM + LinuxCNC" project it's a hobby for me now. I made my own pair of a firmware/driver for the old NVEM (STM32F207). And my work (and scotta's work too) can be moved into the trashcan soon (because of RT1052). My previous project (Orange Pi + LinuxCNC, "allwincnc") was archived because new Linux kernel/uboot pair breaks my work on the built-in CPU's firmware.
So I decided to force the development of my own controller for the LinuxCNC. I planning to use my code (partly) from both of those projects. The PCB will be a simple shield for the cheap modules. See the photos below. Some parts will be replaced to another ones for the simplicity. Planning to create a new topic soon.
4 years 4 weeks ago - 4 years 4 weeks ago #253275 by Bari
The problem with the OrangePi's is availability, that is the only reason why we haven't built a good Linux and u-boot for them.
forum.linuxcnc.org/18-computer/44828-rem...ard?start=480#252695 has a ARM SOC for Linux and LCNC plus a STM32 for Remora for ~$60 usd.
shop.lerdge.com/products/adapter-module   for the stepper driver headers and external stepper drives
@epineh a few STM32's have been ported to Remora. The problem is availability of them since they often have one year lead times or only pop up sporadically.
I design single board computers and my issues are which parts to pick to be sure they are available for the next year or two. I am happy to even design a board for the Chinese to copy and produce cheaply.
forum.linuxcnc.org/18-computer/46077-pot...ters?start=20#251959 is also of interest
Last edit: 4 years 4 weeks ago by Bari.
Time to create page: 0.143 seconds
