3 years 9 months ago #263417 by fintech
Were you ablet to get any V5 board to work correctly in mach3? I hear tons of people having problem. I even have a few comments on the youtube video I posted.
3 years 9 months ago - 3 years 9 months ago #263418 by scotta
I've never used Mach3, so can't say. One of the guys working on the EC500 with LinuxCNC just shared that his board has died, with what appears to be a voltage regulator issue.
Touch wood, I haven't had any issues with the 6  Novusun / Digital Dream boards now in the workshop.
Last edit: 3 years 9 months ago by scotta.
  • REX299
  • New Member
  • New Member
3 years 9 months ago #263428 by REX299
Hi scotta,
I just got St link today, following your video to create DAP link, Step 1 working, my computer shows 2nd ST link as removeable storge, But I have problem with Step 2. When I finished drag "stm32f103xb_mimxrt1050_qspi_if.bin" file to storge, nothing happens until I try to open one of 2 files on Maintenace, it reset itself then show fail log file.
Fail log file:
"error: The transfer timed out.
type: transient, user"
Any idea?
Thank you.!
3 years 9 months ago #263463 by itsmaxdd
Hello,
amazing reverse eng work!
Do you happen to know which Mach3 version you have backed up?
I started to play with this board and my laser but since i bought it from aliexpress i really feel like there will be no improvement (i'm having a bit of hard time using it with mach3).
How is the overall experience with linux cnc? never used it before
3 years 9 months ago #263483 by fintech
Got my second ST-Link programmed. I get a error file in the directory after reboot when I try and flash remora-rt1052.bin. The ST-Link Looks the DAP-Link is working correctly. I'm going to try and flash from MCUexpresso. What SDK's do I need to install? Never used MCUexpresso but I've I've used visual studio code and arduino IDE allot.
3 years 9 months ago - 3 years 8 months ago #263484 by fintech
I'm getting a network error when compiling. Did know if I was missing a SDK or there is a syntax error. All the errors I'm getting are ethernet related.
../source/ethernet.c:30:73: error: 'phy_handle_t' {aka 'struct _phy_handle'} has no member named 'mdioHandle'
Last edit: 3 years 8 months ago by fintech.
Time to create page: 0.594 seconds
