- Thank you received: 5
Definitely a speed improvement at 600MHz clock speed. I've started to re-look at DMA stepgen with the hope of increasing the step rate. With the fast MCU there may be hope to fill the step buffer fast enough.Now I see what you mean about the IO pinout headache for these BGA processors. At least with the STM32 you can put your leads on the pin. Do you think this new NXP processors is an upgrade or downgrade?
Untested, but looks similar to J-link commands. To read (dump) the following may work, but I have already a copy of the original firmware in the repo.Is there a way with the DAP/Stlink to dump my EC300.bin file?
