3 years 8 months ago #264197 by fintech
Thanks Scott, I got it to work with:
net coolant-flood iocontrol.0.coolant-flood remora.output.6
net coolant-mist iocontrol.0.coolant-mist remora.output.7
Now I need to figure out inputs and spindle.
The following user(s) said Thank You: scotta
3 years 8 months ago #264206 by dec0077
Mine is STM32 based.
I would have to un-wire the board to be able to remove the lid, but I could take a picture if you think it could help
3 years 8 months ago #264211 by Domi
Hello. How do I invert the 0-10V output for the spindle? when stopped I have 10V and at maximum revolutions it is 0V. or will someone provide a hall for the spindle? I use linuxcnc 2.8.2 and NVEM V2. Well thank you
3 years 8 months ago #264247 by scotta
There seems to be a few versions of the STM32 based NVEM v2, especially when it comes to the output circuit for the analogue 0-10v.
There is an example hal using lincurve to invert the output. You will need to adapt the scale and lincurve parameters appropriately.
remora-docs.readthedocs.io/en/latest/sof...incurve-compensation
3 years 8 months ago #264249 by scotta
When you say that the output is always 10v, is this the case when LinuxCNC is not talking with the board? I'm suspicious that your board might have a different circuit and IO pin than the board I used for development. A photo might help but a real pain with the NVEM not having plug headers.
3 years 8 months ago #264251 by fintech
So far this is my working HAL on EC500 V5.
# Basic HAL config file for NVEM controller board running Remora firmware
# Configured for 3 joints (A, Y, Z axes) with home and limit switches
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
# load the Remora real-time component
loadrt remora-nv
# estop and SPI comms enable and feedback
net user-enable-out <= iocontrol.0.user-enable-out => remora.enable
net user-request-enable <= iocontrol.0.user-request-enable => remora.reset
net remora-status <= remora.status => iocontrol.0.emc-enable-in
# add the remora and motion functions to threads
addf remora.read servo-thread
addf remora.update-freq servo-thread
addf remora.write servo-thread
# joint 0 setup (X axis)
setp remora.joint.0.scale [JOINT_0]SCALE
setp remora.joint.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net j0pos-cmd joint.0.motor-pos-cmd => remora.joint.0.pos-cmd
net j0pos-fb remora.joint.0.pos-fb => joint.0.motor-pos-fb
net j0enable joint.0.amp-enable-out => remora.joint.0.enable
# joint 1 setup (Y axis)
setp remora.joint.1.scale [JOINT_1]SCALE
setp remora.joint.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net j1pos-cmd joint.1.motor-pos-cmd => remora.joint.1.pos-cmd
net j1pos-fb remora.joint.1.pos-fb => joint.1.motor-pos-fb
net j1enable joint.1.amp-enable-out => remora.joint.1.enable
# joint 2 setup (Z axis)
setp remora.joint.2.scale [JOINT_2]SCALE
setp remora.joint.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net j2pos-cmd joint.2.motor-pos-cmd => remora.joint.2.pos-cmd
net j2pos-fb remora.joint.2.pos-fb => joint.2.motor-pos-fb
net j2enable joint.2.amp-enable-out => remora.joint.2.enable
#Spindle Control 0V-10V Analog (working with 24K Spindle) At 12K getting 4.96V at 24K getting 9.77V
net spindle-cw remora.output.5
loadrt pwmgen output_type=1
loadrt scale count=1
loadrt lowpass count=1
loadrt abs count=1
addf scale.0 servo-thread
addf lowpass.0 servo-thread
addf abs.0 servo-thread
setp scale.0.gain 0.00416666667
net spindle-cmd-rpm spindle.0.speed-out => scale.0.in
net spindle-cmd-rpm-abs scale.0.out => abs.0.in
net spindle-speed-DAC abs.0.out => remora.SP.0
net spindle-cw <= spindle.0.forward
#Output Coolant Control M7 M8 M9
#Inputs
net estop-ext <= remora.input.24
net home-x <= remora.input.19
net home-y <= remora.input.13
net home-z <= remora.input.12
net spindle-index <= remora.input.5
Time to create page: 0.151 seconds
