3 years 8 months ago - 3 years 8 months ago #263738 by fintech
I've been communicating with another guy on facebook, Looks like there is multiple PCB revisions of  EC500 V5. The MCU communications pins are different. The boards have different dates codes. The boards look almost identical. The only difference that I can see is the area near the MCU header. This might explain my steppers work in LinuxCNC but not mach3. My PCB date code is IMXR_EC500 2022-09-07 and his is IMXR_EC500 2022-08-15. We both got them flashed. I  will put together some pictures. My header pins were labeled. His were not.
Last edit: 3 years 8 months ago by fintech.
3 years 8 months ago #263759 by cncwhacko
Looks like my board revision of the ec500 is 2022-09-07 for what it's worth.
3 years 8 months ago #263768 by fintech
Hey cncwhacko, Did you ever get your board to work in Mach3? We have the same date codes.
3 years 8 months ago #263772 by cncwhacko
nope never used mach3. I'm drawn to the flexibility of linuxcnc
3 years 8 months ago #263775 by scotta
Is there a way with the DAP/Stlink to dump my EC300.bin file?
Untested, but looks similar to J-link commands. To read (dump) the following may work, but I have already a copy of the original firmware in the repo.
pyocd commander -t mimxrt1050_quadspi -c "savemem 0x60000000 0x400000 ec300.bin"
Might give it a try.
I gave this a try and it works!
3 years 8 months ago #263784 by fintech
Does anybody have a sample hal file so I can see how inputs and outputs work with the remora. All configuations I see are for parallel ports or mesa cards. I'm a total rookie with LinuxCNC but not to Linux. Been building Linux webservers for the last 20 years.
Time to create page: 0.730 seconds
