3 years 8 months ago #264252 by scotta
Thanks for sharing, it will definitely help others. You've picked up LinuxCNC quickly.
3 years 8 months ago #264253 by dec0077
I didn't check the voltage on VSO when Linuxcnc is not running, I didn't think it would be useful, but I can do that, it'll be just a minute to do so.
My main issue is of course the output voltage when the system is up&running, as I have everything else working fine with my board (movement, limits, inputs, outputs to enable forward and reverse rotation of the spindle, etc.) but the analog 0-10V.
I'll try to get a picture, but this time I'll leave the lid off, in case I need to access it again. I'm also guessing if, to solve the issue, I'll have to flash a new version of the firmware, I'll have to free the board again... Maybe, without the lid on, I can leave the serial headers soldered on.
I'm getting an oscilloscope, will be here in a few days, so then I should be able to understand what is going on with the VSO output (it's a shame there are no other float pins on the board, just digital ones).
Thank you
3 years 8 months ago - 3 years 8 months ago #264254 by fintech
Thanks, Scott. I kind of cheated. I used the step config generator to create a working config for a parallel port. I wanted to see what a working config looks like. I compared the parallel config against your sample config. The spindle stuff I got from another post on here. You sent my the input and output numbers. I verified everything with my multimeter. I think most people on here probably have a technical background. This isn't for your average sane person.
Last edit: 3 years 8 months ago by fintech.
3 years 8 months ago #264256 by tommylight
You would be amazed at how many people come here claiming to know nothing about electronic/electric/cnc and end up with a working machine in a very short period of time.
A bit of reading and patience and following directions goes a long way to the target.
Analyzing stuff as you did is the best way to a working machine and a wealth of knowledge.
3 years 8 months ago #264257 by dec0077
Here are the pictures of my board, I hope they can give all the info needed.
3 years 8 months ago #264259 by tommylight
STM32F207, that is the micro controller, so probably should use the firmware for it.
Also might want to wait for the more experienced members to reply as i had no time to play with Remora, yet.
Time to create page: 0.650 seconds
