- Thank you received: 33
Great to hear that you got the firmware flashed successfully. I'm pretty certain that you will need the IO power connected so that the MAX3232 is powered up.Hello everyone, this weekend I received my ec300, I managed to flash it without problems by the two methods described here DAPLink and CMSIS-DAP without problems, although I must say that DAPLink only worked for me on Windows since in linux it always fails, CMSIS- DAP only tested on Ubuntu works perfect.
Ok here is my problem, after a lot of fighting to get RS232 serial output connected directly to the DIP COM onboard pins of my motherboard, which I couldn't get to work
EC300 Motherboard
RXD pin ----> PIN3
Pin TXD ----> PIN2
The JCOM physical serial port of my motherboard works because making a short between pins 2 and 3 I have a return on CuteCom, RealTerm etc.
Almost given up I decided to solder two wires to the R2OUT T2IN pins, skipping the MAX3232 IC and !!!!eureka!!!!! using a USB-TTL(FT232RL) I had a serial output, from my point of view I have the MAX3232 IC of my EC300 wrong.
I have not tested if the nvmpg works, it would be hard to check it because it works with the LPUART5 which is also connected to the MAX3232 IC, I am waiting for a new order for some stlink since the one I had has died.
I ask for some advice about it!!!!!
1
