3 years 8 months ago #264602 by Domi
Thank you very much. I also used 1uF. Now it's about 0.5 seconds from 0-10V.
3 years 8 months ago #264715 by AlessandroEmm
Hey there,
sorry if i missed it, would anyone have the pinout for the Headers of the NVEM Board (on the underside) with the later RT1052 MCU?. Unfortunately those dont have any marking on the pinout.
Thanks!
Alessandro
3 years 8 months ago #264719 by scotta
Hey there,
Thanks!
Alessandro
You can find it here
forum.linuxcnc.org/18-computer/44828-rem...ard?start=470#252585
3 years 8 months ago #264739 by AlessandroEmm
Thanks Scott, but thats for the EC300 I understand? Would the NVEM use the same order of pinout?
3 years 8 months ago #264984 by dec0077
I finally got my oscilloscope today and put it to work right away.
This first image is what I get out of the optocoupler; Voltage goes from -10V to +8V and the wave is all but square... the less said about the duty cycle, the better.
This second one is the output on VSO (sorry for the quality, it was difficult to take a picture while holding the probe to one of the pins); again goes both positive and negative, is about 250mV p-p and does not approximate a ramp in any way, shape or form.
Given these waveforms, I think I'll not be able to drive the spindle directly, it's almost as if the PWM section of my board is faulty.
What do you think?
Best Regards,
Alberto
3 years 8 months ago #265083 by rbobey1989
Hi Scott, I've been testing with remora-rt1052 for a couple of days and there has been progress, as I mentioned before I managed to fake remora-rt1052.bin without problems, I installed the remora-nv component, I ping the board without problems, LinuxCnC Exits E-Stop as expected, homing ok, Gcode execution starts, but I get !!!!following errors!!!!! sporadic in LinuxCnC, I have tried lowering the speedups, changing the FERROR and MIN_FERROR and I have not had any luck, I have taken as first reference the sample configuration of remora-nvem-basic and the remora-nv component from Scott's repository for a clean configuration to perform tests.
github.com/scottalford75/Remora-NVEM/tree/main/LinuxCNC
I can't think of anything else to try if you have an idea of course it will be well received.
I am going to prepare LinuxCnC in RPI4 to test since right now I am on a computer with debian 12 but enough for today 2:37 am, exhausted. ideas please......
Time to create page: 0.335 seconds
