- Thank you received: 489
I've just had another look at the RT1052 code and looks to be an issue with the encoder inputs. I'll put the EC300/NVEM back on the bench to test.are these the correct inputs for rt1052 nvem?
net mpg-a encoder.0.phase-A <= remora.input.28
net mpg-b encoder.0.phase-B <= remora.input.27
I cant see where in the code the mpg encoder is being read.
Thank you for your help and your hard work putting this together.
Cheers
The INDEX input is a digital input, normally connected to a spindle sensor. In LinuxCNC the HAL would need to be set-up appropriately as well.Hello. Anyone using INDEX Input on nvem v2? I have connected 0-5V from vfd to INDEX input nvem. Speed is not shown on the display. Something needs to be changed in HAL. ? Well thank you
I've just done a bug fix, pushing version 0.0.1 to the Develop branch. I've got NVMPG jogging working on the bench.
Cheers
Murphy wrote:
This is great work. Currently doing a Denford mill retrofit with parallel cards. I also have an emco little CNC waiting to get converted. Is it possible to get these to work with encoder inputs? Ie a toolchanger?.
I'll also add Encode and QEI features to the list.
NVEM has two available QEI interfaces available for high speed counting on FHA + FHB and INP7 + INP8.
EC500 has three available QEI interfaces available for high speed counting on IN5 + IN6, IN9 + IN10 and IN12 + IN13. One of these is on TIMER1 so I'll setup the DMA step generation on TIMER8.
For a tool changer software encoder support should be more than adequate.
First your work is awesome Scott, I think there's really much support here than from the company. Do you think one of these input can handle the index pulse for the spindle PID on the EC500, I saw the V5 have a pin for this and but mine is older. I'm currently on mach3 but I really thinking about taking the big dive for linuxcnc!
