4 years 6 months ago #239009 by Domi
I also adjusted the lines 12,13,14 according to royk but it doesn't work. Then I used the original but it still doesn't work. It gives an error. Can't advise where to bounce?
4 years 6 months ago #239014 by royka
Read, it says unknown command "remora.SPI-enable". So you didn't change that line
4 years 6 months ago #239018 by Domi
I changed it as you wrote. How else can I change it?
4 years 6 months ago #239019 by Domi
4 years 6 months ago - 4 years 6 months ago #239020 by royka
Haha i meant change remora.SPI-enable to remora.enable.
Here is the file as how I meant:
raw.githubusercontent.com/royka1/Remora/...a-eth/remora-eth.hal
Last edit: 4 years 6 months ago by royka.
4 years 6 months ago #239021 by Domi
How did you comment on joint 3? Now it shows me a joint 3 scale not found error
Time to create page: 0.724 seconds
