- Thank you received: 135
Can the OPI5 be Configured to Run LCNC?
- royka
3 years 4 months ago - 3 years 4 months ago #273625
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
@buzzFab I wasn't aware of the size limit of mega.nz. Did you try to use a working Ubuntu Jammy image and install the kernel deb package that's in the folder of the image I had uploaded?
This is the compressed image which is 1.18 GB instead of 5.92 GB:
mega.nz/file/mkAj0ADb#kOVsoqYLxDANBkXT2R...oZ83G4Og2jwaKIpWqwtU
Last edit: 3 years 4 months ago by royka. Reason: Compressed image
The following user(s) said Thank You: buzzFab
- royka
3 years 4 months ago #273702
by royka
@buzzFab I've finally received the OPi5+
The image I had uploaded doesn't work as is. It does load the dtb and kernel but then it's looking for an UUID that isn't in armbianEnv.txt or fstab, perhaps something wrong in the dtb or uboot.
Tomorrow I'll look further into it, perhaps using a working image and install the rt-kernel that I had uploaded will still work.
- buzzFab
- Thank you received: 7
3 years 4 months ago #273705
by buzzFab
Replied by buzzFab on topic Can the OPI5 be Configured to Run LCNC?
@royka I actually tried your image last night and it only booted to the (initramfs) prompt. I then built a xfce jammy image and download the debs from your folder. when i tried to install them with the gui only one would install, I cant remember which one.
- buzzFab
3 years 4 months ago #273743
by buzzFab
You can now get a passively cooled aluminum case for the OPi5 and OPi5b on AliExpress or Amazon.
www.aliexpress.com/item/1005005558033596.html
www.amazon.com/Orange-Pi-Aluminum-Materi...atible/dp/B0C6K6QQXT
- royka
3 years 4 months ago - 3 years 4 months ago #273764
by royka
@buzzFab Here is a working image:
mega.nz/folder/78Z3UbRD#Pl8DdWmxLF3CDma21An8gQ
The only thing I noticed was that it gave an error about owner rights of the user folder, but this could've been due to that I pushed the reset button by accident after the first boot.
To fix this: sudo chown -R username:username /home/username
The latency was a bit higher as usual, about 12 uS, but probably because of no cooling, the same kernel on the opi5 performed good.
For this kernel I did a bit of a different approach, made a patch out of the difference of the rt53 branch and the normal branch till the same date and applied that patch to the kernel of xunlong.
Actually hoped that I could apply the patch to the more updated kernel of Armbian or Joshua Riek (5.10.160) but that didn't work. But this kernel is more up to date than the patched rt-kernel
- buzzFab
3 years 4 months ago #273765
by buzzFab
@royka do i need to do anything with the files in your .deb directory?
Time to create page: 0.668 seconds
