Can the OPI5 be Configured to Run LCNC?
- ccc774
2 years 1 week ago #312965
by ccc774
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
anyway I appreciate the effort. Thank you.
- royka
- Thank you received: 135
2 years 1 week ago #313219
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
Found a possible cause, which might explain why nvme works on OPI5-plus and sata on OPI5, but nvme doesn't on OPI5:
forum.armbian.com/topic/46601-2484-lates...mment&comment=204829
Here the deb where I removed the revert:
drive.google.com/drive/folders/1r76sUsfG...6fGcz?usp=drive_link
- ccc774
2 years 6 days ago #313257
by ccc774
Now is working. Thank you.
The following user(s) said Thank You: royka
- ccc774
2 years 5 days ago #313290
by ccc774
I tried to activate the spi and the usart in armbian-config/Toggle hardware configuration, but the peripherals don't appear there.
- royka
2 years 5 days ago #313304
by royka
Possibly the names don't match since you copied the folder with the dtb files and overlays.
It might be easier to add them manually in /boot/armbiEnv.txt
There you'll see "overlay_prefix=" and "overlays=", these should match with the filenames in /boot/dtb/rockchip/overlay/
So for example rk3588-uart6-m1.dtbo and rk3588-spi4-m1-cs0-spidev.dtbo it will be:
overlay_prefix=rk3588
overlays= uart6-m1 spi4-m1-cs0-spidev
And make sure that the overlays don't overlap each other, so don't activate therm all.
- ccc774
2 years 4 days ago #313336
by ccc774
I tried this but I had a conflict in the uarts declarations. I solved it.
Where can I read how the realtime rtapi_app process is assigned to core 7?
How can I assign realtime priority to a process that uses the uart?
Time to create page: 0.162 seconds
