- Thank you received: 135
Can the OPI5 be Configured to Run LCNC?
- royka
2 years 2 weeks ago #312426
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
Like tommylight said and I want to add that you should also check /boot/armbiEnv.txt for the same UUID. When you see a /boot mount in fstab you could remove that line too.
Here it didn't recognize the ID option by the way, in that case just leave that away, alternatively you could issue the blkid command to see the UUID.
- ccc774
2 years 2 weeks ago - 2 years 1 week ago #312432
by ccc774
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
first of all, thank you for your prompt answers.I can boot with kernel 6.1.75-vendor-rk35xx, with the 6.1.75-rt23 .debs installed, but without making the link (sudo ln -sf vmlinuz-6.1.75-rt23 Image). If I reboot and then make the link, it doesn't boot anymore. In /proc/cmdline I don't see any value for ubootpart=.
Last edit: 2 years 1 week ago by ccc774.
- Thank you received: 7491
2 years 2 weeks ago #312434
Thank you for reminding me, now i will go on and forget it promptly!
Replied by tommylight on topic Can the OPI5 be Configured to Run LCNC?
I could not recall this to save my life when i was answering this!... alternatively you could issue the blkid command to see the UUID.
The following user(s) said Thank You: royka
- ccc774
2 years 2 weeks ago #312435
by ccc774
I can read all the IDs in /drv/disks...., but I don't know how to enter it to recognize it.
2 years 2 weeks ago #312439
rootdev=UUID= lotsofnumbershere
those lots of numbers have to be replaced by the ID of your drive
- ccc774
2 years 2 weeks ago - 2 years 1 week ago #312443
by ccc774
The ID returned by blkid is the same that I have in armbianEnv and it is the same ID that it says it does not recognize when booting.
Time to create page: 0.319 seconds
