- Thank you received: 135
Can the OPI5 be Configured to Run LCNC?
- royka
2 years 1 month ago #310516
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
@nhanpan You probably need to pin the ethernet irq to another core, preferably an isolated core. The irq you can get by entering the command: cat /proc/interrupts and find your ethernet adapters. In case yours also start with "enP" you could enter:
grep enP /proc/interrupts
To pin them to cpu5 with the above result as example you could add to /etc/rc.local in a line above "exit 0"
sleep 15 && echo 20 > /proc/irq/185/smp_affinity & echo 20 > /proc/irq/186/smp_affinity
It seems that the error tells that the kernel doesn't support that, perhaps a missing module? But with the irqs pinned you can ignore the message.
185: 0 0 0 0 799186 0 0 0 ITS-MSI 428343296 Edge enP3p49s0
186: 0 0 0 0 0 0 0 0 ITS-MSI 570949632 Edge enP4p65s0
The following user(s) said Thank You: nhanpham
- royka
2 years 1 month ago #310519
by royka
@briansm The 6.1 kernel is a bsp kernel so I doubt it patched successfully, you might have more luck with patching the 6.11 kernel including these patches and use the right config:
github.com/armbian/build/tree/main/patch...rockchip-rk3588-6.11
But some things might not work yet. If you can't figure it out, maybe I'll take a look at it sometime. But for now I don't see much added value in it.
- nhanpham
2 years 1 month ago #310556
by nhanpham
Replied by nhanpham on topic Can the OPI5 be Configured to Run LCNC?
Thank you very much. After reinstalling the kernel, adding iptables, and assigning IRQ to core 7, everything worked perfectly. I was able to run with SERVO_PERIOD = 500,000 for 6 hours without any issues.
grep enP /proc/interruptsCode:185: 0 0 0 0 799186 0 0 0 ITS-MSI 428343296 Edge enP3p49s0 186: 0 0 0 0 0 0 0 0 ITS-MSI 570949632 Edge enP4p65s0 To pin them to cpu5 with the above result as example you could add to /etc/rc.local in a line above "exit 0" sleep 15 && echo 20 > /proc/irq/185/smp_affinity & echo 20 > /proc/irq/186/smp_affinity It seems that the error tells that the kernel doesn't support that, perhaps a missing module? But with the irqs pinned you can ignore the message.
The following user(s) said Thank You: royka
- s.o.v.a
- Thank you received: 8
2 years 3 weeks ago #311320
by s.o.v.a
Replied by s.o.v.a on topic Can the OPI5 be Configured to Run LCNC?
Hi, guys!
It seems that using a GPU improves latency on this board.
Without:
With:
Good thread:
dietpi.com/forum/t/orange-pi-5-hardware-...tion-enabled/16387/2
If you are using Armbian Jammy, you just follow the instructions. (You may encounter two errors that are easy to google)
I'm using Bookworm so manually installed .debs
Without:
With:
$ glxinfo | grep Device
Device: llvmpipe (LLVM 14.0.0, 128 bits) (0xffffffff)
# no hardware acceleration
Device: Mali-G610 (Panfrost) (0xffffffff)
# hardware acceleration here
Good thread:
$ ls
libd3dadapter9-mesa_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libdri2to3_1.0.5-2_arm64.deb
libegl1-mesa_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libegl-mesa0_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libgbm1_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libgl1-mesa-dri_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libgl1-mesa-glx_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libgl4es_1.1.4-1+git230404.22af242~j2_arm64.deb
libglapi-mesa_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libgles2-mesa_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libglx-mesa0_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libmali-g610-x11_1.0.5-2_arm64.deb
libosmesa6_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
libwayland-egl1-mesa_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
mali-g610-firmware_1.0.2_all.deb
malirun_1.0.5-2_all.deb
mesa-opencl-icd_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
mesa-va-drivers_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
mesa-vdpau-drivers_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
mesa-vulkan-drivers_23.0.5-0ubuntu1~panfork~git221210.120202c6757~j3_arm64.deb
# all *arm64*.deb files excluding *dev* (development stuff)
$ sudo apt install ./*.deb
The following additional packages will be installed:
libclang-common-14-dev libclc-14 libclc-14-dev libllvm14 libvdpau1 libvulkan1 ocl-icd-libopencl1
Recommended packages:
libclang-rt-14-dev
The following NEW packages will be installed:
libclang-common-14-dev libclc-14 libclc-14-dev libd3dadapter9-mesa libdri2to3 libegl1-mesa libgl1-mesa-glx libgl4es libgles2-mesa
libllvm14 libmali-g610-x11 libosmesa6 libvdpau1 libvulkan1 libwayland-egl1-mesa mali-g610-firmware malirun mesa-opencl-icd
mesa-va-drivers mesa-vdpau-drivers mesa-vulkan-drivers ocl-icd-libopencl1
The following packages will be upgraded:
libegl-mesa0 libgbm1 libgl1-mesa-dri libglapi-mesa libglx-mesa0
5 upgraded, 22 newly installed, 0 to remove and 0 not upgraded.
$ sudo reboot
The following user(s) said Thank You: tommylight, royka, onceloved
- royka
2 years 3 weeks ago - 2 years 3 weeks ago #311533
by royka
6.11 also seems to give good results, rt patched the source from:
github.com/Joshua-Riek/linux-rockchip/tree/oracular
Audio doesn't work here and perhaps some other features are missing, for those who would still like to try:
Kernel deb package and config:
drive.google.com/drive/folders/1JglCIPKv...cjOvr?usp=drive_link
An easy way to install with gpu acceleration is to install the image 6.10.6 with backported mesa from:
mirror.vinehost.net/armbian/dl/orangepi5/archive/
or
mirror.vinehost.net/armbian/dl/orangepi5-plus/archive/
Install the kernel with: sudo apt install ./linux*.deb
Then copy the dtb files: sudo cp /usr/lib/linux-image-6.11.0-rt7-g375956b48579-dirty/rockchip/* /boot/dtb/rockchip/
And link the Image file to the rt-kernel: cd boot; sudo ln -sf vmlinuz-6.11.0-rt7-g375956b48579-dirty Image
or
Last edit: 2 years 3 weeks ago by royka.
The following user(s) said Thank You: onceloved
- royka
2 years 3 weeks ago - 2 years 3 weeks ago #311810
by royka
Also tested the 6.1.75 vendor kernel (with panthor driver), only after loading chromium and watching videos on youtube the latency raised a bit as you can see, but still very acceptable. Isolating all the fast cores improved that, but for me it's not worth it as it becomes noticeable slower.
For the rt-patch only a few had to be done manually for the serial 8250 driver because of some vendor edits.
Kernel/config
An easy way to install with gpu acceleration is to install the kernel on the image 6.1.75 with backported mesa from:
or
And link the Image file to the rt-kernel: cd boot; sudo ln -sf vmlinuz-6.1.75-rt23 Image
Kernel/config
or
Time to create page: 3.237 seconds
