- Thank you received: 135
Can the OPI5 be Configured to Run LCNC?
- royka
2 years 6 months ago - 2 years 6 months ago #298309
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
To compile the rt kernel on the OPi5:
Here LinuxCNC 2.10 build from master today:
drive.google.com/drive/folders/1ZqLOGr7l...sLdif?usp=drive_link
git clone https://github.com/orangepi-xunlong/linux-orangepi.git -b orange-pi-5.10-rk35xx-rt
cd linux-orangepi
cp /boot/config-5.10.160-rt89+ ./.config
make menuconfig #Here you can make your changes
make -j$(nproc)
sudo make modules_install
sudo make install
Last edit: 2 years 6 months ago by royka.
The following user(s) said Thank You: angelnu, briansm
- vre
- Thank you received: 17
2 years 6 months ago #298984
by vre
Replied by vre on topic Can the OPI5 be Configured to Run LCNC?
Orange pi 5 can work with the onboard header I/O with linuxcnc ?
- royka
2 years 6 months ago #299020
by royka
- vre
2 years 6 months ago #299160
by vre
also with spi connection to mesa card like rpi4 ?
- Thank you received: 426
2 years 6 months ago #299162
Replied by Cant do this anymore bye all on topic Can the OPI5 be Configured to Run LCNC?
I don't know if there is a SPI driver like the RPi from Linuxcnc (this is a dedicated driver for only the Rpi3/34), as per the RPI the /dev/spidev driver probably wont give you the speed you are after.
Unless you already have a 7c80 or 7c81 I'd tend to stay away from the SBC's and go for a small form factor x86 system (if space is a concern) and an ethernet mesa card. That way you wont be stuck when you need to update\replace the computer. Ethernet is everywhere, SPI seems to be the realm of the non-x86 platforms, and each SBC will require it's own driver, which requires someone to develop & maintain it and you are at the whim of the manufacturers\dealers regarding availability........and the infinite number of models.
Another thing to take into account some of these SBC's require messing about with the uboot loader, or whatever flavour of boot loader is used, to use a realtime kernel.
They have their place, it just depends how much time you are willing to spend and whether it will be obsolete in a couple of months to a year.
- vre
2 years 6 months ago #299166
by vre
This seems very good for use with mesa ethernet card + extra ethernet for internet
www.hardkernel.com/shop/odroid-h4-plus/
Time to create page: 1.058 seconds
