2 years 4 months ago #303970 by meister
have update the board config in git and build and upload a new bitstream file.
i have the same problem with openFGPALoader and MachXO3 from lattice :(
2 years 4 months ago #303972 by Cant do this anymore bye all
It may have been the fault of mine, I changed the flash chip out, it may have been a dodgy one. I'll chase up an original M25P40 and put it back on.
In the meantime I have access to a few other Spartan6 boards, one with the same FPGA on it, pins are just a bit different and only 70 GPIO available, but does have 6 LEDS and 4 switches on the board :(
Al least I'll still be able to experiment, got plenty of dupont cables to patch the FPGA board to my daughterboards.
Thanks for all your help, changing things around is pretty straight forward, and after messing with the Mesa firmwares I feel comfortable messing about with it.
2 years 4 months ago - 2 years 4 months ago #304003 by Cant do this anymore bye all
Ok had a play around.Build works OKFlashing works okAfter flashing, when SPI interface not connected, no blinking lights observed.Has to create a new board called Mimas, and the config to go with.Just copied the Spartan6 stuff.After generating everything has browse thru the Ouput/Mimas/Gateware folder everthing was there, pin constraints matched what I need. Just added the "drive setup" for each pin.Still need to setup the Rpi for Linuxcnc.Included some file for you to look at.
Last edit: 2 years 4 months ago by Cant do this anymore bye all.
2 years 4 months ago #304023 by Cant do this anymore bye all
Ok went back to my Lattice dev board, and connected up via SPI, qt test works, LCNC does not. get header message error. Could be my wiring.
Once I finally worked out the pin changes in my sources, from about 12 months or so the UDP bridge works fine, well at least with qt test.
It's 1am, Marc crashed out of the Sprint at Assen (grumble grumble grumble), I'll attack it when the sun is up.
This is beginning to seem like an ID 10 T issue and it's all my fault.
2 years 4 months ago #304061 by meister
if you change the gateware on the FPGA, you have to recompile the hal-component,
the test gui used the json-config, but the hal-component (rio.c) ist generated and need an
halcompile --install rio.c after changes
2 years 4 months ago #304064 by Cant do this anymore bye all
Yep I remembered that.
I'll just keep plodding along and see how I go.
I've ordered some new flash chips and another dev board so at least I can go back to square one.
Just out of interest, with the WT32-ETH01 module should it be powered with 3.3v or 5v ?
Time to create page: 0.504 seconds
