Is your vesion of the Tango board a modified PCB? and is there Kicad or PCB repository. Just so I can compare the difference with Olivers version.I am switching LinuxCNC from an old PC to RaspberryPI + Tango compatible board.
I see that riocore has support for HY_VFD and I want to use it. After resolving simple issues I can get a serial signal out of the Tang Nano, but no connectio to the VFD yet. I guess I will need a TTL to RS485 brekout board. Will this one do?
Last time that I made changes to the HY_VFD configuration it cost me a burnt spindle, so now I'm trying to learn more and if possible from other's experience. I will appreciare any help and suggestions.
Thanks!
-- Itai
Thanks! I forgot it was already on Github! This is the latest that was sent to create the PCB. As I wrote, If I make a new version I would make some changes.no idea if it is up to date:
github.com/itain/Tango-PCB-Kicad
