2 years 1 week ago #313190 by meister
do you already have your layout on github ? then i would create a new board in rio so that you have the pins in the right place.
2 years 1 week ago - 2 years 1 week ago #313192 by gitano
Hello,
after diving a bit more deeply into LinuxCNC-RIO and having a closer look at the Tangbob and riocore, a few questions have come up:
1) almost every connector on the board makes sense to me, except J5 + J6 (Down/ Up) -> what are these connectors for?
2) as i get it, i can use 2 BOB's simultanously with this board, correct? Do these boards still need the 12-24V input on the right side, or is the 5V input only sufficient to drive all Inputs and Outputs correctly? Except for the PWM Output (Spindle Control) on the right side, i bet.
3) do i have to use the BOB's Inputs / Outputs (left and lower Side) as such, or can i map them freely in riocore, f.e. use the - usually stepdir output - pins P2-P5 as Encoder input pins?
4) can i power a LED strip directly via wled1 with the onboard 5V supply, or would an external supply be better?
Secondly i played around with the Tangbob configuration in riocore and as it seems i must be doing something completely wrong or there must be something messed up with the bitin/ bitout defintions for the Tangbob board somewhere:
Board: Tangbob Toolchain: icestorm Protocol: UDP LinuxCNC: 3 Axis mill manual toolchange axis gui Modules: china bob left -> split Plugins added: ads111514 on i2c             -> all ok wled bar on wled             -> all ok modbus1 on modbus             -> all ok stepdir on RIGHT: P2 + P2         -> all ok stepper17 on RIGHT: P3 to P6        -> all ok quadencoder on RIGHT: P10 - P12     -> all ok bitout on RIGHT: P8            -> compiles well
but the latter gives a long error message when firing up LinuxCNC:
riocomp.c:185:28: error: expected ‘:’, ‘,’, ‘;’, ‘}’ or ‘__attribute__’ before ‘OUT_BIT’   185 |     hal_bit_t   *SIGOUT_P8 OUT_BIT;       |                            ^~~~~~~ [...and TONS of similar/ follow up errors]
looking at riocomp.c:185 reveals:
"hal_bit_t   *SIGOUT_P8 OUT_BIT" <- looks like a missing underscore between P8 and OUT, with added underscore i just get:
    linuxcnc rio.ini  LINUXCNC - 2.10.0~pre0 Machine configuration directory is '/media/gitano/Alhambra/Software/Linux/CAD+CAM/LinuxCNC-RIO/riocore/Output/Tangbob/LinuxCNC' Machine configuration file is 'rio.ini' Starting LinuxCNC... linuxcncsvr (563355) emcsvr: machine 'Rio - mill'  version '1.1' linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Note: Using POSIX non-realtime milltask (563384) task: machine 'Rio - mill'  version '1.1' halui (563390) halui: machine 'Rio - mill'  version '1.1' twopass:invoked with <> options twopass:found ./rio.hal twopass:found ./pregui_call_list.hal twopass:pass0: loadusr -W hal_manualtoolchange riocomp.c: In function ‘register_signals’: riocomp.c:541:51: error: ‘data_t’ has no member named ‘SIGOUT_P8’   541 |     if (retval = hal_pin_bit_newf  (HAL_IN, &;(data->SIGOUT_P8 OUT_BIT), comp_id, "%s.P8 OUT.bit", prefix) != 0) error_handler(retval);       |                                                   ^~ riocomp.c:541:62: error: expected ‘)’ before ‘OUT_BIT’   541 |     if (retval = hal_pin_bit_newf  (HAL_IN, &;(data->SIGOUT_P8 OUT_BIT), comp_id, "%s.P8 OUT.bit", prefix) != 0) error_handler(retval);       |                                              ~               ^~~~~~~~       |                                                              ) riocomp.c:542:10: error: ‘data_t’ has no member named ‘SIGOUT_P8’   542 |     *data->SIGOUT_P8 OUT_BIT = 0;       |          ^~ riocomp.c:542:21: error: expected ‘;’ before ‘OUT_BIT’   542 |     *data->SIGOUT_P8 OUT_BIT = 0;       |                     ^~~~~~~~       |                     ; riocomp.c: In function ‘convert_varout1_bitout19_bit’: riocomp.c:1013:23: error: ‘data_t’ has no member named ‘OUT_BIT’  1013 |     bool value = *data->OUT_BIT;       |                       ^~ make: *** [/usr/share/linuxcnc/Makefile.modinc:117: riocomp.o] Error 1 # compiling and loading rio component...failed
adding the same fix in line 541, 542 and adding SIGOUT_P8_ before OUT_BIT in line 1013 as well as uncommenting OUT_BIT in rio.hal and custom_postgui_hal, axis GUI fires up. The defined button for P8 shows up fine in GUI, i guess it won't work with hardware, though.
I tried adding bitins and outs for other boards (iceshield and octobot) and there they work fine.
All in virtuality, i still have no hardware around, but that will change soon image missing /media/kunena/emoticons/smile.png
Cheers,
-lgitano
P.S.: Dont know if it is correct to post such userspace/ configurations issues here as this thread perhaps gets quite huge, or if it would be better to open new board specific threads? If You think so, i will do the latter :)
Last edit: 2 years 1 week ago by gitano.
2 years 1 week ago #313194 by meister
1) its a jumper to set pullUP/pullDown resistors to the signal-lines
2) yes, but, if you meen the cheap China BOB's, 12/24V is needed for the Opto's
3) you can freely use the pins on the board, but on the BOB, there are Opto's and Darlington-Arrays that works only in one direction.
4) i think up to 10 LED's are ok, if you need more, then i would use en extra 5V supply
PS) as you prefer / but i need you config file with the P8 error, it looks like there is one space too many in the config ('P8 ')
The following user(s) said Thank You: gitano
2 years 1 week ago - 2 years 1 week ago #313203 by gitano
aah, stupid me -> i actually named that pin "P8 OUT" in the Name section, changing the name to "P8_OUT" -> all works well x)
regarding 1) - 4) -> that clarifies a lot, thank You very much!
Well, i am considering ordering a small batch from JLPCB, the last layout on github (edited in August) is working ok, so far?
speaking about that and looking at the prices there i am considering getting some octobot and iceshield boards as well, they look too tempting to ignore and would be fun to toy around with image missing /media/kunena/emoticons/smile.png
I am still not sure about 2 things regarding the iceshield:
- ball soldering sounds indeed frightening... i tried that once with a CPU socket of an old mainboard (bent pins) and failed completely x) There is a version on here with pre-soldered SMD parts, maybe i should go this route?
- as i get it, the communication between RPI and shield goes via SPI, so just 4-5 pins, correct? what about the other GPIO pins, can these still be used f.e. by soldering a connector on top of the shield? Is there actually a component for using these with LinuxCNC?
Thank You very much!
Cheers,
-lgitano
2 years 1 week ago #313205 by meister
the tangbob board is updated 2weeks ago,
because i had problems with the 1.8V pins:
github.com/multigcs/rio-tangbob
this updated version is not tested, but it should work (there is only a new diode to drop the voltage on the level-shifters)
the ICE40 on the iceshield board is not BallGrid but also hard to solder by hand,
not necessarily the FPGA, but the 2.5V diode, which is extra small and you don't really recognize the direction.
I would wait for digiex_chris's Version or ask him if he have a spare one.
Octobot: remember that the icewerx board also costs money.
RPI-Pins:
MOSI, MISO, SCLK, CS0, CS1, GPCKL0, GND, 3.3V, 5V
all other pins are not connected and freely usable, don't know if there was a ready to use lcnc component, but a little python-script will do the job
The following user(s) said Thank You: kostas, gitano
2 years 1 week ago #313209 by meister
the 'spaces in name' problem is fixed, i replace it with '_' now.
Time to create page: 0.123 seconds
