3 years 3 months ago - 3 years 3 months ago #276137 by meister
encoder component ?
what you mean ?
i using this encoder:
www.amazon.de/gp/product/B08PDLFKBM/ref=..._title?ie=UTF8&psc=1
the hal component is inside the rio driver
setp rio.PV.4-scale 600 net spindle-position rio.PV.4 => spindle.0.revs net spindle-index-enable rio.PV.4-index-enable <=> spindle.0.index-enable
Last edit: 3 years 3 months ago by meister.
The following user(s) said Thank You: MaxEkb77
3 years 3 months ago #276139 by meister
its in a new branch: g33
and there are maybe problems with the free toolchain,
i used the original gowin tools for this
3 years 3 months ago - 3 years 3 months ago #276144 by MaxEkb77
I see in sources component encoder (vin_quadencoderz).
ohh need test all :)
Last edit: 3 years 3 months ago by MaxEkb77.
3 years 2 months ago - 3 years 2 months ago #277129 by fest
I recently stumbled upon this topic- looks really impressive project. I'm currently building a milling machine and was planning on using linuxcnc and mesa, however this looks a tempting alternative for my use case.
I'm not afraid from building the needed electronics and fiddling with building the gateware as I have some leftover Colorlight ecp5 modules, have experience with open source fpga tools (though, with LiteX/amaranth, very rudimentary verilog knowledge), and have another cnc machine planned, so the work would be amortised over more than a single machine.
My main question would be: what might I be missing out by using this instead of mesa? Are there known features not implemented yet (I think my needs are rather modest: up to 5 step/dir axes up to 6 incremental encoders, digital inputs/outputs). I'm not really sure where the closed motion control loop is being executed usually- is it Linuxcnc, or does mesa have support to do closed loop stepgen in hardware (which doesn't seem to be supported here, right?)
Last edit: 3 years 2 months ago by fest. Reason: Removed a question that has been discussed expensively
3 years 2 months ago - 3 years 2 months ago #277143 by meister
Hi fest,
I don't have any mesa cards, so I can't tell you what's missing.
But if you miss something, let me know and I'll try to add it.
I think mesa also uses the pid controllers in linuxcnc.
About the colorlight boards i have to say that the networkport is not supported, you need 4 free pins for SPI and either a UDP2SPI bridge or a raspberry.
5 step/dir axes up to 6 incremental encoders should be no problem if you have enough pins.
EDIT: do you know this project ?: forum.linuxcnc.org/27-driver-boards/4442...roller-board?start=0
Last edit: 3 years 2 months ago by meister.
3 years 2 months ago - 3 years 2 months ago #277151 by fest
Hmm, thanks for the pointer, LiteXCNC also looks quite interesting. Direct Ethernet support is indeed intriguing, though it also appears that IO options are more limited in LiteXCNC.
The modules I have are SODIMM, with FPGA, SDRAM and 2x GigE phy, not the boards with LED buffers, so pin availability is not a problem. I'll probably design my carrier board to be compatible with both projects (so far it seems that LinuxCNC-RIO only needs an SPI header while LitexCNC needs the phy) and see what works best for me.
Time to create page: 0.231 seconds
