- Thank you received: 3
3 years 2 months ago #279579
by serdigi
Replied by serdigi on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Hello;
Congratulations. Thank you for sharing this economical and efficient project with us. My question is: What is the maximum step frequency in 4 axes? Have you had a chance to test it? Thank you. Kind regards...
3 years 2 months ago #279581
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Thanks, but I can't say what the maximum is, but I can say that the FPGA is not the limiting component
and that it doesn't depend on the number of axes, but that all stepgen/pwm run in parallel
3 years 1 month ago #280182
by fest
Replied by fest on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Designed and ordered a single-axis evaluation board for Colorlight i5 (+/-10V analog output, step/dir, RS422 encoder input, a couple of inputs) to test out the Lichuan servo and Ditron scales I have on order. It is not a complete solution yet, but perhaps useful to someone following along at home:
github.com/festlv/linuxcnc-rio-servo-eval
The following user(s) said Thank You: meister, Cant do this anymore bye all
- Thank you received: 426
3 years 1 month ago #280205
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Just maybe my friend
Cheers
Cheers
3 years 1 month ago - 3 years 1 month ago #280221
by fest
Are you and/or @meister working on something similar? If that's intended as an open-source hardware project, perhaps you need help?
Last edit: 3 years 1 month ago by fest.
3 years 1 month ago #280235
I've got a couple of boards I designed a few years ago, but currently they don't have an RS-422 interface on them. So would be interested in your implementation as a reference.
Tho I did grab2 of these to play with, hopefully have a SPI490, if not no harm
Time to create page: 0.215 seconds
