1 year 10 months ago #316312 by MirkoCNC
Ups, I have just seen the correct IO standard can be configured /edit in the plugin of the blink module in the riocore software. Hence, it is not necessary to do it manually in the pins.cst file.
1 year 10 months ago #316313 by meister
i have removed the IO_TYPE from the cst pinfile generation,
you need to checkout the newest dev branch and generate the files new
1 year 10 months ago - 1 year 10 months ago #316321 by meister
Now, after the first start of the generator, a file is created:
riocore/toolchains.json
there you can enter the paths to your toolchains, these are then transferred to the makefile.
under windows please note that backslashes must be double
so you do not need to add the toolchains to your enviroment variables
Last edit: 1 year 10 months ago by meister.
1 year 10 months ago #316330 by MirkoCNC
I pulled the dev branch.
It creates the toolchains.json file and I added:
"gowin": "C:\\Gowin\\Gowin_V1.9.10.03_Education_x64\\IDE",
"diamond": "",
"vivado": "",
"quartus": "",
"icestorm": "",
"ise": ""
However, it does not compile. It gives me following error:
Der Befehl "make" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Furthermore, the graphic in the tab Overview is completely gone.
1 year 10 months ago #316334 by MirkoCNC
As I have no hardware yet, I am wondering if it is good decision to remove IO_TYPE completely.
It was just my mistake because I have not realized that it can be set within your tool.
The IDE shows me in the Pin Report that all pins are on LVCMOS18 now.
I
Time to create page: 0.553 seconds
