1 year 3 months ago #331166 by Tim Bee
Dear meister:
 when I updated RIO, I got error:
riocomp.c: In function ‘register_signals’:
riocomp.c:692:52: error: ‘data_t’ has no member named ‘SIGIN_QUADENCODERZ0_INDEXOUT_INDEX_RESET’; did you mean ‘SIGIN_QUADENCODERZ0_INDEXOUT_not’?
  692 |     if (retval = hal_pin_bit_newf(HAL_OUT, &(data->SIGIN_QUADENCODERZ0_INDEXOUT_INDEX_RESET), comp_id, "%s.quadencoderz0.indexout-reset", prefix) != 0) error_handler(retval);
      |                                                    SIGIN_QUADENCODERZ0_INDEXOUT_not
riocomp.c:694:52: error: ‘data_t’ has no member named ‘SIGIN_QUADENCODERZ0_INDEXOUT_INDEX_WAIT’; did you mean ‘SIGIN_QUADENCODERZ0_INDEXOUT_not’?
  694 |     if (retval = hal_pin_bit_newf(HAL_OUT, &(data->SIGIN_QUADENCODERZ0_INDEXOUT_INDEX_WAIT), comp_id, "%s.quadencoderz0.indexout-wait", prefix) != 0) error_handler(retval);
Tim
1 year 3 months ago #331175 by meister
Hi Tim,
sorry for that, is now fixed in 'main' branch
The following user(s) said Thank You: tommylight, Tim Bee
1 year 3 months ago #331227 by Happppppppy
Hi Meister,
I have setup a board file and config for the Terasic DECA max10 board and connected a W5500 module but it isn't showing up with the correct ip address.
I can confirm that the board is flashing (I'm using the quarts programmer to flash) as the LEDs change when I add or remove a bitout plugin.
The SPI clock and chip select looks right and signals are showing up on my scope on both mosi and miso lines (I don't have a digital decoder so can't interrogate the codes themselves).
The w5500 is showing up as a network device with what seems to be 5 default addresses (when I use arp -a in CMD)
Any thoughts on why the W5500 isn't configuring with the 192.168.10.194 address? I can share my board and config files and the compile output if that helps.
Thankyou!
1 year 3 months ago #331230 by meister
do have configure one of your network-interface to the 192.168.10.xxx range ?
please add you config and the output of:
ip a s
and
ip r s
1 year 3 months ago - 1 year 3 months ago #331232 by Happppppppy
I don't have any devices configured with 192.168.10.xxx on the linuxcnc computer.
Here is the config:
"name": "BushmasterFPGA",
"description": "Terasic DECA Max10",
"boardcfg": "TerasicDECAMax10",
"protocol": "UDP",
"plugins": [
"type": "w5500",
"mac": "AA:AF:FA:CC:E3:1C",
"ip": "192.168.10.194",
"port": 2390,
"pins": {
"mosi": {
"pin": "Header Right:GPIO1_D0"
"miso": {
"pin": "Header Right:GPIO1_D1",
"pull": "down"
"sclk": {
"pin": "Header Right:GPIO1_D2"
"sel": {
"pin": "Header Right:GPIO1_D3"
"rst": {
"modifier": [
"type": "invert"
"pin": "Header Left:GPIO0_D4"
"uid": "w55000"
"linuxcnc": {
"ini": {
"EMC": {
"MACHINE": "BUSHMASTERFPGA"
"KINS": {
"JOINTS": 4,
"KINEMATICS": "trivkins coordinates=XYYZ kinstype=both"
"TRAJ": {
"COORDINATES": "X Y Y Z"
"machinetype": "mill"
Here are the outputs from the terminal:
cnc@BUSHMASTER-CNC:~$ ip a s
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether f8:0f:41:80:f0:e7 brd ff:ff:ff:ff:ff:ff
altname enp0s25
inet6 fe80::696b:7c3c:f7c9:4de2/64 scope link noprefixroute
cnc@BUSHMASTER-CNC:~$ ip r s
Last edit: 1 year 3 months ago by Happppppppy.
1 year 3 months ago #331236 by Tim Bee
Dear meister:
Thanks for your repay and fix it,thanks again.
Tim
Time to create page: 0.449 seconds
