Remora for RP2040
3 years 2 months ago - 3 years 2 months ago #278179 by drewnabobber
Replied by drewnabobber on topic Remora for RP2040
I found that pgain of 500 and ff1gain of 1 made a big difference.  I also found some things in the firmware that seemed to help and I have posted a PR with my changes.
Last edit: 3 years 2 months ago by drewnabobber.
3 years 2 months ago #278204 by scotta
Replied by scotta on topic Remora for RP2040
Thanks for the work on this, greatly appreciated! I've merged your changes and will do some tests as well. How's the PicoBob hardware working out?
3 years 2 months ago #278227 by scotta
The changes have made a huge difference! pgain of 100 seems to be adequate, so I'll update the config to include that as default. ff1gain is set to 1 by default. Higher pgains actually created following errors at high speed by overshooting.
3 years 2 months ago #278294 by drewnabobber
That sounds good. The PicoBOB DLX hardware is ready to go IMO. Everything works and seems to be in the correct place :) I will be posting the design very shortly to Github. If you want to reach out to me on Discord or something I am sure I can get you one sooner.
That said. Pausing the threads for the data copying seems to make the step timing jitter pretty bad. I'm going to try implementing a ping-pong buffer and use pointers in the threads so that they are only interrupted for as long as it takes to do an assignment and see if that helps.
3 years 2 months ago #278322 by scotta
Great idea, something which all the Remora versions would benefit from.
3 years 2 months ago #278960 by drewnabobber
For anyone interested I have posted the PicoBOB-DLX hardware to Github here:
github.com/Expatria-Technologies/PicoBOB-DLX
The following user(s) said Thank You: scotta, cakeslob
Time to create page: 0.108 seconds
