Remora for RP2040
2 years 10 months ago #289203 by cakeslob
Replied by cakeslob on topic Remora for RP2040
dont use the eth, it is most likely outdated. your hal file is asking for remora-nv
2 years 10 months ago #289229 by fklco
Replied by fklco on topic Remora for RP2040
Thanks! Now works, but over 100mm/min feed I receive a Joint 1 or 2 following error.
I use a old Dell E5500 for test and I want to be shure if latency is problem or my settings.
Thanks.
2 years 10 months ago #289231 by cakeslob
Did you load your pico pin configuration to the board using the upload_config.py ?
Try with this configuration, it should work.
github.com/Expatria-Technologies/linuxcn...ain/picobob-ethernet
2 years 10 months ago #289309 by fklco
I do all settings from Expartia github link and now support velocity until 7500mm/min but some time crash with 'joint X following error', error is random not every time in same 'place' of gcode and joint nr cud be any. (0,1,2). The crash dont appear every time, for example 3 time run all code without problem and 4 th time crash 2 times.
I suspect the latency problem.
2 years 10 months ago #289313 by tommylight
Replied by tommylight on topic Remora for RP2040
From what i can gather, it is a latency issue, the screenshots you posted are terrible but that might be due to using base period for tests.
The main issue is you still get the warning about latency excursions on the servo period when starting LinuxCNC, and that has to be addressed first.
2 years 10 months ago - 2 years 10 months ago #289372 by fklco
Hall scope on Joint0 fferror
When works ok. At Feed 4000 and G0 at 7500mm/min
When crash
At low speed Feed 400mm/min and G0 2000mm/min
I think is PID problem not latency.
Edit : With firmware form hire github.com/scottalford75/Remora-RP2040-W5500/tree/main/build is more stable now, but need PID adjust.
Last edit: 2 years 10 months ago by fklco.
