Solution fo "hm2 error finishing read" with no good PC
28 Oct 2024 17:09 #313380 by greg23_78
I need help because I don't know what to do with my PC.
At the moment linuxcnc displays ‘hm2 error finishing read’ every time I change the tool on my turret on my cnc lathe.
several weeks ago I had this message sometime.
below the latency of my pc and the ping for the ethernet.
I have disabled all the options that slow down latency in the bios/uefi.
I have followed the procedure to isolate a core for linuxcnc. and other procedure to reduce latency (IRQ affinity scripts / rt_setup).
but i have the problem ‘hm2 error finishing read’, is there any solution to remove this problem or the only solution is to replace the pc because nothing can be done?
28 Oct 2024 17:54 #313381 by PCW
The issue is the 5.835 ms maximum ping time (about 10X the usable maximum)
My guess is that you have a RealTek Ethernet interface on you PC which requires
and alternate driver (DKMS) be installed since the driver supplied with the 6.1 kernel has
real-time issues.
Instructions for this are in this thread:
forum.linuxcnc.org/27-driver-boards/5366...xcnc?start=20#310794
Before you do that is probably best to determine the actual Ethernet hardware with say:
lspci | grep -i ether
29 Oct 2024 10:44 #313423 by greg23_78
i did, but still the same.
i have done ping 10.10.10.10 during the nigh and i have lost some packet.
my hardware is Realtek RTL8111/RTL8168
29 Oct 2024 15:08 - 29 Oct 2024 15:09 #313438 by PCW
Have you added
pcie.aspm=0 r8168.eee_enable=0 pcie_aspm=off idle=poll
to the kernel command line? (via grub)
Sometimes that is needed also.
To make sure you are running the dkms driver, try running this script:
File Name: edriver.txt
File Size:0 KB
To run this, first
chmod +x edriver.txt
and then
./edriver.txt
(from the Downloads directory)
and paste the results here.
(not my script but nicely lists network drivers)
Last edit: 29 Oct 2024 15:09 by PCW.
29 Oct 2024 15:49 #313442 by greg23_78
i added the same as the google doc "r8168.aspm=0 r8168.eee_enable=0 pcie_aspm=off loglevel=3"
i changed and add " pcie.aspm=0 r8168.eee_enable=0 pcie_aspm=off idle=poll" but still the same "hm2 error finishing read" (I restarted the PC)
29 Oct 2024 17:13 - 29 Oct 2024 17:20 #313446 by PCW
That looks like the standard realtek 8168 driver rather than the DKMS driver
so it sounds like the DKMS driver install did not work for some reason
Last edit: 29 Oct 2024 17:20 by PCW.
29 Oct 2024 17:53 #313448 by royka
Perhaps a newer kernel helps, here is version 6.10 rc1
drive.google.com/drive/folders/1L28lG0zD...2XQJx?usp=drive_link
30 Oct 2024 10:36 #313477 by rodw
Please follow steps 44-58 in the google doc on the other thread.
I don't think you have installed the r8168-dkms driver.
30 Oct 2024 17:06 #313500 by rajsekhar
IRQ to be set to last cpu. That had worked for me.
12 Nov 2024 10:08 #314309 by greg23_78
This are the screenshots when I try to install r8168-dkms.I did not delete the first installation at the start of the post
Time to create page: 0.455 seconds
