Solution fo "hm2 error finishing read" with no good PC
1 year 11 months ago #314394 by PCW
Can you run this script:
File Name: edrivers.txt
File Size:132 B
and post the results here?
first make executable with:
chmod +x edrivers.txt
then
./edrivers.txt
1 year 11 months ago #314399 by tommylight
This is what i get:
cnc@15ALC7:~$ ls -1 /sys/class/net/ | grep -v lo | xargs -I{} bash -c 'echo -n {} :" " ; basename `readlink -f /sys/class/net/{}/device/driver`' enxc84d44297a21 : r8152 wlp2s0 : rtw_8822ce cnc@15ALC7:~$
1 year 11 months ago - 1 year 11 months ago #314429 by greg23_78
i get like before
cnc@cnc:~$ ls -1 /sys/class/net/ | grep -v lo | xargs -I{} bash -c 'echo -n {} :" " ; basename `readlink -f /sys/class/net/{}/device/driver`' enp2s0 : r8168 cnc@cnc:~$
My PC is a Dell Optiflex 3040
Last edit: 1 year 11 months ago by greg23_78.
1 year 11 months ago #314458 by PCW
So looks like the DKMS driver (I think the default driver with latency issues "8169")
So not sure whats going on.
What does your kernel command line look like?
cat /proc/cmdline
1 year 11 months ago #314461 by greg23_78
the command return to me :
cnc@cnc:~$ cat /proc/cmdline BOOT_IMAGE=/boot/vmlinuz-6.1.0-23-rt-amd64 root=UUID=9ccb36b6-0014-43a8-b35e-c8724d432dac ro initrd=/install/gtk/initrd.gz quiet isolcpus=3 pcie.aspm=0 r8168.eee_enable=0 pcie_aspm=off idle=poll
1 year 11 months ago #314465 by PCW
Did you try pinning the Ethernet IRQ?
As a test you can run this script:
File Name: pinirq_2024-11-14.txt
File Size:668 B
chmod +x pinirq.txt then:
sudo ./pinirq.txt enp2s0
And then retry LinuxCNC or the ping test
Time to create page: 0.422 seconds
