PCI and PCI-E add on cards with parallel port that work out of the box
1 year 7 months ago #325184 by ContinenteCNC
Model: PAR5408AXX200
Chipset: Sunix SUN1989
Interface: PCIe
Supports PS/2: YES
Supports EPP: NOT TESTED
Supports IN Mode: YES (in PS/2 Mode)
Supports X Mode: NO (Control port pins voltage drops to ~0,3 V when connected to ground through 470 ohms resistor, but pins states won't change)
Tested OS: linuxcnc-2.8.4 / Debian Buster
Tested Computer: Dell Optiplex 760
1 year 7 months ago #325185 by tommylight
Do they show driver and module in use?
I would guess at yes... as the flags are only "medium devsel"
1 year 7 months ago #325190 by ContinenteCNC
No, neither of them. The last picture in each post is everything coming out of sudo lspci -v
It seems it has something to do with Sunix chipsets.
1 year 7 months ago #325193 by tommylight
OK, thank you, i am a bit fuzzy today on everything due to lack of sleep and some other "issues".
The following user(s) said Thank You: ContinenteCNC
1 year 7 months ago #325198 by unknown
The asm1083 is a PCIe to PCI bridge. The other chip would be the chip with the parallel etc functions.
Photos are ok, but the real bit of important info is the PCI ID number.
If you look at the text file I attached a couple of posts ago as well as having info regarding the parallel port cards it also has a couple of commands as where to get the info from the file system. Like what mode the card supports and stuff like that.
1 year 7 months ago #325214 by ContinenteCNC
Don't worry!
Btw, my 4 yo daughter just loves your profile picture xD
Time to create page: 0.358 seconds
