- Thank you received: 240
Tool offset patch
- ArcEye
14 years 1 month ago #24464
by ArcEye
Replied by ArcEye on topic Re:Tool offset patch
Hi
I find git very aptly named sometimes! It can be very frustrating.
The answer I believe is to delete the rebase-apply directory which is inside the hidden .git directory in the root of the file tree.
- LAIR82
- Thank you received: 3
14 years 1 month ago #24466
by LAIR82
Replied by LAIR82 on topic Re:Tool offset patch
How do get to where i delete it out?
- BigJohnT
- Thank you received: 994
14 years 1 month ago #24469
by BigJohnT
Replied by BigJohnT on topic Re:Tool offset patch
Open up the file manager and check off show hidden files then you should be able to see the .git directory.
14 years 1 month ago #24470
Replied by andypugh on topic Re:Tool offset patch
ArcEye wrote:
It might be worth trying:
git reset --hard origin/master
(or origin v2.5_branch if that is the branch you are patching)
- LAIR82
14 years 1 month ago #24474
by LAIR82
So just delete the whole rebase-apply folder?
- LAIR82
14 years 1 month ago #24481
by LAIR82
I moved that folder to my thumb drive, I re-tried loading the patch and this is what I get now
srt@Cinci:~/linuxcnc-dev$ git am --signoff 0001-Fanuc-style-tool-change-for-Lathes.-On-Fanuc-control.patch
Applying: Fanuc-style tool change for Lathes. On Fanuc-controlled lathes (as well Fanuc-like lathes like Haas, Okuma, and likely others). tool changes are not commanded with an M6, and offsets are not applied with G43. Rather the T word both commands a tool change and applies offsets. The offsets on Fanuc lathe controls are stored in two separate registers: geometry and wear. The wear offset register has IDs in the 1-99 range, the geometry offset register has IDs in the 10001 - 10099 range. A T word followed by one or two digits causes a tool change and applies only the geometry offsets. A T word with three or four digits also applies the wear offsets.
/home/srt/linuxcnc-dev/.git/rebase-apply/patch:41: trailing whitespace.
CHP((find_tool_pocket(settings, geo_offset_register, &index)));
/home/srt/linuxcnc-dev/.git/rebase-apply/patch:45: trailing whitespace.
CHP((find_tool_pocket(settings, wear_offset_register, &index)));
/home/srt/linuxcnc-dev/.git/rebase-apply/patch:50: trailing whitespace.
/home/srt/linuxcnc-dev/.git/rebase-apply/patch:74: trailing whitespace.
error: patch failed: src/emc/rs274ngc/interp_convert.cc:3511
error: src/emc/rs274ngc/interp_convert.cc: patch does not apply
error: patch failed: src/emc/rs274ngc/interp_find.cc:707
error: src/emc/rs274ngc/interp_find.cc: patch does not apply
error: patch failed: src/emc/rs274ngc/interp_internal.hh:723
error: src/emc/rs274ngc/interp_internal.hh: patch does not apply
Patch failed at 0001 Fanuc-style tool change for Lathes. On Fanuc-controlled lathes (as well Fanuc-like lathes like Haas, Okuma, and likely others). tool changes are not commanded with an M6, and offsets are not applied with G43. Rather the T word both commands a tool change and applies offsets. The offsets on Fanuc lathe controls are stored in two separate registers: geometry and wear. The wear offset register has IDs in the 1-99 range, the geometry offset register has IDs in the 10001 - 10099 range. A T word followed by one or two digits causes a tool change and applies only the geometry offsets. A T word with three or four digits also applies the wear offsets.
When you have resolved this problem run "git am --resolved".
If you would prefer to skip this patch, instead run "git am --skip".
To restore the original branch and stop patching run "git am --abort".
Time to create page: 1.035 seconds
