Tool offset patch
13 years 5 months ago #34223 by DaOne
Replied by DaOne on topic Re:Tool offset patch
LAIR82,
Any chance I can get you to give a step by step of what you did to install this Fanuc style tool change patch? I am a new user to LinucCNC (coming from Mach3) I have managed to come a long way on my own (got everything working including upgrading to the master version so I can play with Gscreen). I for the life of me can not figure out how to apply this patch and coming from using Haas lathes its a must have. I have Git installed and have ran the git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev command successfully. After that I am lost. I want to keep the master version (2.6 pre) and use this patch. I hope you can help?
-Wes
13 years 5 months ago - 13 years 5 months ago #34234 by LAIR82
Replied by LAIR82 on topic Re:Tool offset patch
Hello Wes,
This should summarize it, there has been alot of discussion lately on this though, and Cmorley is in the works of giving it a tune-up, and hopefully pushing it to master, so t will just be a switch in your INI file, but here you go.
1. Download the following attachment,
2. Go to your Home folder, and move the folder you downloaded to the linuxcnc-dev folder that you created.
3. Open up your linuxcnc-dev folder, right click on the downloaded zipped folder, and click "Extract here"
4. After you have extracted the file, open a terminal window, and change to the linuxcnc-dev directory.
5. Once there, I would perform the "ls" command and make sure you see the .patch file listed.
6. If you see the patch file, then from the command line perform "git am --signoff lathe_style_tool_change2.patch" This will apply it to the appropriate files in he src folders. You will probably see an error for "trailing whitespace" disregard, I get the fault but the patch is applied and will work.
7. Now you need to re-compile, after compiling, it should be there and work properly.
Let me know if you get hung-up, I should be able to help
Rick
Last edit: 13 years 5 months ago by LAIR82. Reason: added zip file
13 years 5 months ago #34260 by DaOne
Ok, I think where I am having problems is the re-compile. Not sure exactly what I am doing. Gonna have to read more. I got all the way to step 6 on my own before I asked. The "trailing whitespace" error did come up and i thought I did something wrong.
13 years 5 months ago #34271 by BigJohnT
Replied by BigJohnT on topic Re:Tool offset patch
The trailing whitespace warning can be ignored.
JT
13 years 5 months ago #34272 by DaOne
BigJohnT,
Can you describe step by step how I do this... "7. Now you need to re-compile, after compiling, it should be there and work properly."?
Thanks for all the help guys!
13 years 5 months ago - 13 years 5 months ago #34275 by jlviloria
Replied by jlviloria on topic Re:Tool offset patch
Rick.
There's something wrong here, apply this patch but it does not work, I thought I had done wrong the process, but apply it manually. and feel the same, does not really apply changes nothing.
This version corrects the error removes deleted from the table?
Jorge Viloria
Last edit: 13 years 5 months ago by jlviloria.
Time to create page: 1.259 seconds
