- Thank you received: 6
Tool offset patch
- DaOne
13 years 5 months ago #34300
by DaOne
Replied by DaOne on topic Re:Tool offset patch
Ok I figured it out...
Python was the issue and this fixed it...
sudo apt-get install libboost-python-dev
Make works now!
Make works now!
- BigJohnT
- Thank you received: 994
13 years 5 months ago #34302
by BigJohnT
Replied by BigJohnT on topic Re:Tool offset patch
YEA!
- DaOne
13 years 5 months ago #34303
by DaOne
Damn well it looks like the patch is not working. I added the line FEATURES = 64 to the RS274NGC section of my INI file as it says in the directions. I still get "tool 101 not found" when i type T0101 in MDI. I am using Gscreen - lathe sim to test this.
- Thank you received: 2181
13 years 5 months ago #34307
Replied by cmorley on topic Re:Tool offset patch
Did the tool change right away (without M6) - if so the patch is working.
You must have a tool 1 and tool 10001 in the toolfile for the T0101 call to work.
(don't forget to hit 'apply' in the tool offset editor after editing.
Chris M
Chris M
- DaOne
13 years 5 months ago #34308
by DaOne
I will give it a try Chris, I was trying the whole thing over again hoping I screwed up somewhere.
Will report back in a couple minutes. Thanks!
Will report back in a couple minutes. Thanks! Please Log in or Create an account to join the conversation.
- jlviloria
13 years 5 months ago #34309
by jlviloria
Replied by jlviloria on topic Re:Tool offset patch
Chris this version works better, at least not blocked by applying a compensation having some value in 1000n, grateful.!
Thanks.
Jorge Viloria
Thanks.
Jorge Viloria
Time to create page: 0.271 seconds
